Inheritance Hierarchy
    ArcGIS.Core.CIM Namespace (ArcGIS.Core)
    This namespace contains types used for the Cartographic Information Model.
    Classes
     ClassDescription
    Class Represents 3D layer properties which contain properties used for 3D draw.
    Class Represents 3D symbol properties, a collection of symbol properties that apply when the symbol is used in a 3D context.
    Class Represents activity.
    Class A field holding the result of an aggregation of multiple field values.
    Class Describes the appearance of aggregated features.
    Class Represents a technique for visually reducing large numbers of features in a map by aggregating them.
    Class Represents an ArcGIS Server service connection.
    Class Represents altitude parameters.
    Class Represents an angle format.
    Class Represents animated symbol properties, a collection of symbol properties that apply when the symbol layer has animation data.
    Class Represents a graphic and list of keyframes indicating properties that can be changed during the animation.
    Class Represents an animation screen graphic group container.
    Class Properties defining the graphic at a single point in time for the animation.
    Class Represents an annotation layer used to draw annotation feature classes.
    Class Represents an annotation sublayer used to draw annotation feature classes subclasses.
    Class Represents an area legend patch, small rectangles used to display legend classes.
    Class Represents an aspect ratio.
    Class Represents an attachment graphic frame.
    Class Represents attachment media info.
    Class Represents an attribute condition.
    Class Represents the camera settings associated with a map frame on a page layout.
    Class Represents auxiliary raster properties.
    Class Represents an individual arrow in CIMAviationNorthArrow.
    Class Represents a aviation north arrow which displays declination of true, grid and magnetic north.
    Class Represents the properties for the variation text which is displayed in aviation north arrow.
    Class Represents an aviation-specific Vertical Scale Bar.
    Class Represents a set of scale properties for aviation-specific Vertical Scale Bar, such as a feet scale or meter scale properties.
    Class Represents Business Analyst Color Coded Layer Area Of Interest properties.
    Class Represents Business Analyst Color Coded Layer area of interest item.
    Class Benchmark Comparisons properties.
    Class Represents Benchmark Comparison Results Pane settings.
    Class Represents Business Analyst Color Coded Layer bivariate colors renderer properties.
    Class Represents a background callout which draws a callout with an optional polygon background and leader line.
    Class Represents Business Analyst Color Coded Layer Properties.
    Class Represents Color Coded Layer Results Pane settings.
    Class Represents Business Analyst Color Coded Layer feature class based area of interest item.
    Class Represents Business Analyst Color Coded Layer feature layer based area of interest item.
    Class Represents a Business Analyst Suitability Analysis field-based criterion.
    Class Represents Business Analyst Color Coded Layer graduated colors renderer properties.
    Class Represents Business Analyst Color Coded Layer graduated symbol renderer properties.
    Class Represents Business Analyst Color Coded Layer level of detail.
    Class Represents a balloon callout. Balloon callouts are a filled background that is placed behind text. They may or may not have a leader line connecting the callout to an anchor point.
    Class Represent a neighboring geography information used in Benchmark Comparisons.
    Class Represents a Business Analyst Suitability Analysis point layer-based criterion.
    Class Represents a bar chart marker, a chart made of vertical bars displaying values.
    Class Represents bar chart media info.
    Class Represents Business Analyst Color Coded Layer renderer properties.
    Class Represents Business Analyst Results Pane settings.
    Class Represents a layer of geographic information in a map.
    Class Represents the base class for index feature surround elements.
    Class Represents a basic feature layer, the base class for all layer types that draw feature classes as features.
    Class Represents a basic row template.
    Class Represents Business Analyst Color Coded Layer standard geography based area of interest item.
    Class Represents a Business Analyst Suitability Analysis criterion.
    Class Represents a Business Analyst Suitability Analysis layer.
    Class Represents Suitability Analysis Results Pane settings.
    Class Represents a sub-layer of a Business Analyst Suitability Analysis layer.
    Class Represents a Business Analyst Suitability Analysis target site layer.
    Class Represents Business Analyst Color Coded Layer unclassed colors renderer properties.
    Class Represents Business Analyst Color Coded Layer unique values renderer properties.
    Class Represents a Business Analyst Suitability Analysis demographic variable-based criterion.
    Class Represents Business Analyst variable list.
    Class Represents variable of at variable list.
    Class Represents a binary reference in a document.
    Class Represents a bind variable.
    Class Represents a technique for reducing features by aggregating them into polygon bins.
    Class Describes the appearance and application behavior of polygon aggregation bins.
    Class Contains a collection of properties that describe a bivariate attribute field.
    Class Represents additional authoring properties used by a bivariate choropleth renderer.
    Class Represents a visual effect for reshading the scene to black and white.
    Class Represents a post-processing technique that reshades the scene with a glow effect.
    Class Represents a visual effect for reshading the scene with a blueprint style.
    Class Represents a spatial bookmark.
    Class Represents a bookmark document which is the document type used for saving .bkmx files.
    Class Bookmark map series is a means to create a series of map pages based on saved bookmarks.
    Class A map series page based on a bookmark.
    Class Represents a surface effect for reshading the surface with a borderlands effect in 3D views.
    Class Represents a building discipline layer.
    Class Represents a building discipline scene layer.
    Class Represents a building composite layer.
    Class Represents a building composite scene layer.
    Class Represents a callout.
    Class Represents a camera effect definition to be applied to a 3D view.
    Class Represents carousel media info.
    Class Composite layer to hold all the dynamic content of a Catalog layer.
    Class Represents a layer which dynamically loads its sublayers according to scale and extent constraints.
    Class Represents a CGA attribute, the symbol attribute as specified by the CGA code in the rule package.
    Class Represents a character marker.
    Class Provides access to members that control chart properties.
    Class Provides access to members that control chart axis properties.
    Class Provides access to members that control bar chart series.
    Class Provides access to members that control box plot series.
    Class Provides access to members that control CalendarHeat series.
    Class Provides access to members that control DataClock series.
    Class Represents a band for a variable to be plotted over time.
    Class Represents the bands for a variable to be plotted over time.
    Class Represents arguments to be used to plot change detection over time.
    Class Represents a dimension value for a given variable to be plotted over time.
    Class Represents dimension values for a given variable to be plotted over time.
    Class Represents a dimensional profile chart series.
    Class Represents a variable to be plotted over time.
    Class Provides access to members that control properties of the fill symbol.
    Class Layout element used to display a chart.
    Class Provides access to members that control general chart properties.
    Class Define the properties to define a chart guide.
    Class Provides access to members that control histogram series.
    Class Provides access to members that control chart legend properties.
    Class Provides access to members that control line series.
    Class Provides access to members that control properties of the line symbol.
    Class Represents the definition of a location for which data is to be plotted.
    Class Represents a chart marker, a marker used to display a chart.
    Class Provides access to members that control properties of the marker symbol.
    Class Provides access to members that control MatrixHeat series.
    Class Represents chart media info.
    Class Represents a chart part, individual components of the chart marker.
    Class Provides access to members that control pie chart series.
    Class Represents a slice in the pie chart.
    Class Provides access to members that control probability plot series.
    Class Provides access to members that control profile graph series.
    Class Depicts feature values as a chart drawn over the feature itself.
    Class Provides access to members that control scatter plot matrix series.
    Class Provides access to members that control point chart series.
    Class Provides access to members that control chart series properties.
    Class Represents a chart spectral profile series.
    Class Represents a band to be plotted over a line.
    Class Represents a dimension value for a given variable to be plotted over a line.
    Class Represents dimension values for a given variable to be plotted over a line.
    Class Represents the layer to be used as an additional input.
    Class Represents a surface profile chart series.
    Class Represents chart text properties.
    Class Provides access to members that control time binning properties.
    Class Represents the definition of a track or point for which data is to be plotted.
    Class Represents a trajectory profile chart series.
    Class Represents the definition of a variable for which data is to be plotted.
    Class Represents a class break.
    Class Represents a class break renderer.
    Class Represents additional authoring properties used by a class breaks renderer.
    Class The base class for class breaks renderer types.
    Class Represents a vector marker clipping path.
    Class Represents a cloudy weather effect to be applied to a scene.
    Class Represents a technique for reducing features by aggregating them into point clusters.
    Class Represents a color in the CMYK color model.
    Class Supports colors in the CIM model by providing low level access to properties common amongst all color types.
    Class Represents a color class break.
    Class Represents a classified color visual variable.
    Class Represents a post-processing technique that reshades the scene with adjusted color and luminance.
    Class Indicates whether modulation should be used to render the point. Low modulation values will darken the point color.
    Class Supports color ramp schemes in the CIM model by providing low level access to properties common amongst all color ramp types.
    Class Represents list of color replacement rules.
    Class Represents a color replacement rule.
    Class Supports colors spaces by providing a common base type for all color spaces.
    Class Represents color substitution, an ordered list of color substitutes.
    Class Represents a color unique value.
    Class Represents a color visual variable.
    Class Represents column chart media info.
    Class Represents a composite callout. Composite callouts are a filled background along with an optional shadow, which is placed behind text. They may also have a leader line (consisting of one or both of a simple line, and filled dart) connecting the callout to an anchor point. Composite callouts may have additional surrounding text elements. The text representing these parts is specified in the text string using tags. Their relative position properties are specified in the CIMCompositeCallout through their corresponding CIMCompositeTextPartPosition elements specified below, but these properties can also be overridden with tag attributes.
    Class Represents a composite sublayer.
    Class Represents the text part position properties on a callout part.
    Class Defines a condensed tab.
    Class Represents a condition.
    Class Defines a contiguous tab for a referenced grid.
    Class Supports continuous color ramp schemes by providing low level access to properties common amongst all continuous color ramp types.
    Class Represents a surface effect for adding contour lines to surfaces in 3D views.
    Class Represents a contour interval scale break.
    Class Represents a visual effect for reshading the scene with a cross mosaic texture.
    Class Represents a Cruising Altitude Diagram.
    Class Represents a currency format.
    Class Represents a custom grid of the mapFrame.
    Class Defines the label template for custom grids.
    Class Represents a custom number format.
    Class Represents a slice box exploratory analysis definition.
    Class Represents database relationship info that is used to represent layer or table level overrides.
    Class Represents a data connection.
    Class Contains the field statistics.
    Class Provide information of a preview chart.
    Class Provide access to the statistic column.
    Class Contains a statistic value.
    Class Represents a data engineering statistics view.
    Class Represents a standard date and time format. https://docs.microsoft.com/en-us/dotnet/standard/base-types/standard-date-and-time-format-strings.
    Class Represents a datum transform.
    Class Represents the properties of a declination calculated using World Magnetic Model.
    Class Represents an object with a unique identity within a CIM project or document.
    Class Contains filters so that only features satisfying these definitions will be displayed.
    Class Represents the data for simulating camera depth of field effect in 3D scenes.
    Class Represents a dictionary renderer where symbols are drawn from a symbol dictionary.
    Class Represents an dimension layer used to draw dimension feature classes.
    Class Represents a dimension shape as used by a dimension feature.
    Class Represents an dimension style which defines dimension appearance.
    Class Represents a direction format.
    Class Represents a single bind variable.
    Class Represents a display filter used to restrict the display of features across scale ranges.
    Class Represents a display table.
    Class Represents a unit along with its display settings.
    Class Represents a category of display units.
    Class Represents the display unit settings for the project.
    Class Represents high level information for a document.
    Class Depicts numeric values as a quantity of dots drawn within polygon features.
    Class Represents a double filled alternating scale bar.
    Class Represents a dual scale bar on a page layout.
    Class Represents a dynamic service layer.
    Class Defines the properties needed to specify new Z values when creating or modifying features.
    Class Represents an editing template.
    Class Represents a collection of editing templates.
    Class Represents an item that can be stored within an editing template collection.
    Class Represents a reference to an editing template.
    Class Represents an editing template relationship.
    Class Represents editing template tool options.
    Class A CIM representation of an element.
    Class Represents a series of graphic elements stored offline.
    Class Represents an elevation surface layer.
    Class Represents an ENC layer data connection.
    Class Represents generic ENC display settings.
    Class Represents an Electronic Navigational Charts (ENC) layer.
    Class Represents an ENC sublayer used to access features by type.
    Class Represents an ENC subtable.
    Class Represents an exploratory analysis definition.
    Class Represents the properties required for authoring an Arcade expression.
    Class Represents expression media info.
    Class Represents an extent indicator which is used to display the visible extent of other map frames in an associated map frame.
    Class Class that represents an exterior tick for a grid.
    Class Represents an external table view.
    Class Represents eye-dome lighting properties.
    Class Defines the URI and required field properties for the Indoors Facility layer required for floor filtering operations.
    Class Represents a feature dataset data connection.
    Class Represents the extrusion properties of a feature layer.
    Class Represents a layer that draws data from feature classes.
    Class Represents mosaic feature sub layer.
    Class Represents a technique for visually reducing large numbers of features in a map.
    Class Contains information about the field name and sort order used to draw features.
    Class Represents a feature table.
    Class Represents the trajectory feature sublayer.
    Class Represents a fence geotrigger.
    Class Represents a field description.
    Class Represents a field mapping that maps fields from source layer or table to target layer or table.
    Class Represents a fill which defines how the polygonal geometry is drawn.
    Class Represents a Knowledge Graph Filtered Find Paths Configuration.
    Class When the ID property has a value, represents a single entity. When the ID property is null, represents entities of a given entity type, filtered by PropertyFilterPredicate if it is not empty.
    Class Represents an error of a Filtered Find Paths search.
    Class Represents a Knowledge Graph Filtered Find Paths Path Filter. A path filter can be used for a specific instance, in this case the ID has a value, or for all instances of a type, in this case the ID is null.
    Class Represents results of a Filtered Find Paths search.
    Class Represents the statistics related to a Filtered Find Paths search. It contains the size of the local graph, and the number of openCypher "expansion" queries that have been issued to construct the local graph. The local graph is an in-memory graph used for pathfinding where a node represents an entity in the Knowledge Graph and an edge represents one or many parallel relationships in the Knowledge Graph. The local graph typically contains (much) less nodes than the Knowledge Graph, but enough nodes and edges to ensure that the pathfinding results are accurate. For example, to guarantee that all paths of length up to 'L' between 'A' and 'B' are present in the local graph, we ensure that the sum of counts of "expansion" queries related to 'A' and 'B' is greater or equal to 'L'.
    Class Represents a color scheme composed of discrete colors.
    Class Provides access to properties of a flood simulation barrier.
    Class Provides access to properties of a flood simulation culvert.
    Class Provides access to properties of a depth raster for flood simulation.
    Class Provides access to properties of a flood simulation layer.
    Class Provides access to properties of a flood simulation object.
    Class Provides access to properties of a rate raster for flood simulation.
    Class Provides access to properties of a simulation sink connection object.
    Class Represents storage for flood simulation data objects.
    Class Provides access to properties of a flood simulation water sink.
    Class Provides access to properties of a flood simulation water source.
    Class Defines the properties needed to identify the Indoors layers and some required fields for each layer which are used for floor filtering operations, as well as properties for the map's floor filter.
    Class Represents floor-aware properties for the layer/table used in floor filtering.
    Class Represents floor filter settings.
    Class Represents a foggy weather effect to be applied to a scene.
    Class Represents a folder connection.
    Class Represents a font variation tag name and value. This is sometimes referred to as a variation-axis tag and variation-axis value.
    Class Represents how one or more attachments can participate in the form. When present in the form, the user has the ability to upload an attachment specific to the form element.
    Class Represents the kinds of attachements that may be uploaded via a form attachment element. There are subclasses for audio, images, video, and so on.
    Class Represents an attachment input that accepts audio files.
    Class Represents a barcode or QR code scanner form input. If the client does not support barcode scanning, a single-line text box should be used.
    Class Represents a set of valid coded values with unique names.
    Class Represents a coded value domain, which includes both the actual value that is stored in the database and the description of what the coded value means.
    Class Represents a form input consisting of a list of values in a drop-down that supports typing to filter. Only one value can be selected at a time.
    Class Represents a date picker form input.
    Class Represents a calendar date picker form input.
    Class Represents an attachment input that accepts documents.
    Class Represents domains for fields. A field's domain defines its valid values.
    Class Represents an atomic part of a form. This is the base class for the various form elements, including inputs connected to fields, grouping of elements into logical sections of the form, adding attachments, and so on.
    Class Represents how a field in the dataset participates in the form.
    Class Represents a container that holds a set of form elements that can be expanded, collapsed, or displayed together.
    Class Represents an attachment input that accepts image files.
    Class Represents the form configuration for when a user edits a feature.
    Class Represents a domain inherited from the parent layer by a subtype. It implies that the domain for a field at the subtyp level is the same as the domain for the field at the layer level.
    Class Represents a collection method for a field's value. This is the base class for the various ways input may be collected from users, such as text boxes, combo boxes, date pickers and so on.
    Class Represents a radio button group form input.
    Class Represents a domain that specifies a range of valid values for a field.
    Class Represents how a relationship between feature layers and tables can participate in the form. When present in the form, the user may have the option to add or edit related records.
    Class Represents an attachment input that captures and attaches signatures.
    Class Represents the kinds of supported files for attachment.
    Class Represents a binary switch, or toggle, form input. This should be used when selecting between two options.
    Class Represents a multi-line text area form input.
    Class Represents a single-line text box form input.
    Class Represents a form element containing read-only text.
    Class Represents a time picker form input.
    Class Reprsents calendar date and time picker, with time offset, form input.
    Class Represents how a utility network associations element can participate in the form. When present in the form, the user may have the option to view related utility network associations.
    Class Represents an attachment input that accepts that a video file should be attached.
    Class Represents a fraction format.
    Class Represents the frame that is associated with some element types (for example, map frame, legends and so on).
    Class Represents GA data connection.
    Class Represents GA iso renderer.
    Class Represents Geospatial Analysis Integrity Tool (GAIT) datasets as a layer and draws its errors, exceptions, and areas in need of validation.
    Class Represents the GA layer.
    Class Represents the GA method.
    Class Represents a Gaussian Splat layer.
    Class Represents general placement properties. This is base class for general placement properties for each label engine.
    Class Represents a generic view.
    Class Represents GDB Error tables as a composite layer and draws the errors.
    Class Represents a layer that draws geographic feature data using a renderer.
    Class Represents a geometric effect, this is base class for all geometric effects.
    Class Represents the add control points geometric effect.
    Class Represents the arrow geometric effect which creates a dynamic line along a line feature with an arrow of a specified arrow type and width.
    Class Represents the buffer geometric effect which creates a dynamic polygon with a specified distance around features.
    Class Represents the circular sector geometric effect which creates a circular sector of a specified radius and start/end angles originating from a point feature.
    Class Represents the control measure line geometric effect.
    Class Represents the cut geometric effect which creates a dynamic line that is shorter on one or both ends than the line feature or polygon outline.
    Class Represents the dashes geometric effect which creates a dynamic multipart line geometry from a line feature or the outline of a polygon based on a template.
    Class Represents the donut geometric effect which creates a dynamic polygon ring of a specified width in relation to the outline of polygon features.
    Class Represents the enclosing polygon geometric effect which creates a dynamic polygon from the spatial extent of a line or polygon feature.
    Class Represents the extension geometric effect which creates a dynamic line that is extended from either the beginning or the end of the line feature at a specified deflection angle and length.
    Class Represents the jog geometric effect which creates a dynamic line with a jog of a specified angle, position, and width in the line.
    Class Represents a geometric effect which creates a localizer feather for aeronautical charts.
    Class Represents the move geometric effect which creates a point, line or polygon that is offset a specified distance in X and Y.
    Class Represents the offset geometric effect which creates a dynamic line or polygon offset at a specified distance perpendicularly from a feature.
    Class Represents a geometric effect which creates a hatch pattern to depict special use airspace for aeronautical charts.
    Class Represents the offset tangent geometric effect which creates a dynamic line along a line feature offset in the direction defined by either the beginning or the end of the line.
    Class Represents the radial geometric effect which creates a dynamic line of a specified length and angle originating from a point feature.
    Class Represents the regular polygon geometric effect which creates a dynamic polygon around a point feature with a specified number of edges. All edges are equal in length and all angles are equal.
    Class Represents the reverse geometric effect which creates a dynamic polygon around a point feature with a specified number of edges. All edges are equal in length and all angles are equal.
    Class Represents the rotate geometric effect which creates a dynamic line or polygon rotated a specified angle from the feature.
    Class Represents the rotate geometric effect which creates a dynamic line or polygon scaled by a specified factor. Vertices are moved in relation to the center point of a feature envelope. Values greater than 1 move vertices away from the center point. Values between 0 and 1 move vertices toward the center point. Values less than 0 draw an inverse dynamic line or polygon where the vertices have crossed to the other side of the center point.
    Class Represents the suppress geometric effect which creates a dynamic line that hides sections of a stroke between pairs control points.
    Class Represents the tapered polygon geometric effect which creates a dynamic polygon along a line feature, whose width varies by two specified amounts along its length, as defined by a percentage of the line feature's length.
    Class Represents the wave geometric effect which creates a dynamic line or polygon along a feature with a repeating wave pattern.
    Class Represents geometry location condition.
    Class Represents common properties for all the geotrigger types.
    Class Represents a Geotrigger feed that uses the device location to provide updates.
    Class Represents the parameters of a geotrigger feature fence.
    Class Represents feed for Geotriggers.
    Class Represents a geotrigger fence filter.
    Class Represents the parameters of a geotrigger fence.
    Class Represents a geotrigger notification properties.
    Class Represents a project.
    Class Represents a glossary table for map product surround elements.
    Class Represents a marker symbol for 3D objects.
    Class Represents a gradient fill which fills polygonal geometry with a specified color scheme.
    Class Represents a gradient stroke which draws linear geometry with a specified color scheme.
    Class Represents a post-processing technique that reshades the scene with a grain effect.
    Class Represents a graphic.
    Class Represents the CIM representation of an element on a page layout.
    Class Represents a graphic frame.
    Class Represents a layer of simple graphic elements.
    Class Represents a graticule for a map frame.
    Class Represents a grayscale color defined by lightness.
    Class Provides access to members that control grid chart properties.
    Class Represents an end point of a component. For ex: The labels for ticks are defined using an endPoint object.
    Class Represents the formatting of a label.
    Class Represents latitudes or longitudes for a graticule. Represents eastings or nothings for a grid.
    Class Defines pattern for a component.
    Class Provides access to members that control the display of grid scatter plots.
    Class Represents the state of a label at a given position on a MapGrid.
    Class Defines the properties needed to perform a COGO ground to grid correction when adding new features.
    Class Represents a group editing template.
    Class Represents a group editing template part.
    Class Represents a collection of layout elements in a group element.
    Class Represents a group footer section in a report.
    Class Represents a group header section in a report.
    Class Represents a group layer which is a simple ordered collection of other layers.
    Class Represents a guide used to snap elements on a page layout.
    Class Represents a UTM Grid Zone Designator Label definition for a MapGrid.
    Class Represents a visual effect for reshading the scene with halftone.
    Class Represents a hatch fill which fills polygonal geometry with a uniform series of parallel line symbols.
    Class Represents a heat map renderer. The heat map renderer draws point features as a continuous color gradient representing the density of the points. The resulting density surface represents the physical proximity between points, optionally weighted by a specified attribute value. The displayed raster surface is dynamic and updates if the source point features are edited.
    Class Represents a visual effect for reshading the scene with a hexagonal mosaic texture.
    Class Represents a highlight activity.
    Class Represents a horizontal bar legend item.
    Class Represents a horizontal legend item.
    Class Represents a color defined by hue, saturation, and lightness.
    Class Represents a color defined by hue, saturation, and brightness (value).
    Class Represents an HTML pop-up format.
    Class Represents attractiveness variable used in Huff Model.
    Class Represents a Huff Model calibration.
    Class Distance properties of the Huff Model calibration item.
    Class Represents a color space defined by an International Color Consortium (ICC) color profile.
    Class Represents illumination properties.
    Class Represents image media info.
    Class Represents an image mosaic sublayer.
    Class Represents an image media presentation page.
    Class Represents an image service layer corresponding to an ArcGIS Server image service.
    Class Represents a indexed scene layer.
    Class Represents an ink graphic.
    Class Represents an in-memory dataset data connection.
    Class Represents an in-memory workspace data connection.
    Class Class that represents an interior tick for a grid.
    Class Represents an internet server connection.
    Class Represents the internet server connection base class.
    Class Define IPS configuration Apple IPS properties.
    Class Define the properties needed to identify IPS layer and table.
    Class Defines the properties for the IPS configuration.
    Class Define IPS configuration GNSS properties.
    Class Defines IPS configuration path snapping properties.
    Class Defines the Portal Item for the IPS Positioning data service.
    Class Defines IPS configuration smoothing properties.
    Class Represents a isosurface.
    Class Represents an exploratory analysis keyframe.
    Class Represents a camera keyframe.
    Class Represents an elevation source keyframe.
    Class Represents a layer keyframe.
    Class Represents a range keyframe.
    Class Represents a surface keyframe.
    Class Represents a time keyframe.
    Class Represents a voxel layer keyframe.
    Class Represents a voxel plane keyframe.
    Class Represents a Knowledge Graph Color Info.
    Class Rules defining which "successor" events are allowed to be after a given "predecessor" event. One implied rule is that a successor event must start at or after the start of the predecessor event. These rules use the notions of "Gap" and "Overlap" defined hereunder. Definition of "Overlap": When the successor event start is before the predecessor event end, the overlap is the time from the successor event start to the predecessor event end. When the successor event start is after the predecessor event end, the overlap is zero. Definition of "Gap": When the successor event start is before the predecessor event end, the gap is zero. When the successor event start is after the predecessor event end, the gap is the time from the predecessor event end to the successor event start.
    Class Represents a Knowledge Graph Data Model Visualization.
    Class Represents a Knowledge Graph Diagram Position.
    Class Constraints on the duration of durative events. Note that this constraint does not apply to punctual events.
    Class Represents a Knowledge Graph Entity Type.
    Class Events can be durative (with both start and end properties) or punctual (with just start or just end property).
    Class Defines the behaviours when event time(s) are missing or wrong.
    Class Defines which entities and relationships are "events".
    Class Represents the paths found by the Filtered Find Paths search. We use a memory-optimized representation to avoid storing redundant information because it is often the case that a path shares some entities and relationships with many other paths, especially if the Filtered Find Paths configuration uses 'KGPathMode.All'. Definition: a relationship group contains Knowledge Graph relationships associated to a single edge in the local graph. Paths are encoded this way: The path 'p' uses relationships groups PathsBuffer[PathsEndIndex[p-1] .. PathsEndIndex[p]], and: - the origin of the first relationship group is the origin of the path - the destination of the last relationship group is the destination of the path A path of length zero (with entity 'e') has a single relationship group containing no relationship and where the origin and the destination are 'e'. The relationships group 'g' has origin EntitiesUIDs[RelationshipsGroupsFrom[g]], destination EntitiesUIDs[RelationshipsGroupsTo[g]]. Its relationships are RelationshipsGroupsUIDsBuffer[RelationshipsGroupsUIDsEndIndex[g-1] .. RelationshipsGroupsUIDsEndIndex[g]]. The relationship RelationshipsGroupsUIDsBuffer[i] has a cost RelationshipsCosts[i]. if RelationshipsFrom[i] >= 0, relationship RelationshipsGroupsUIDsBuffer[i] has origin EntitiesUIDs[RelationshipsFrom[i]] else the relationship has been deleted after pathfinding. if RelationshipsTo[i] >= 0, relationship RelationshipsGroupsUIDsBuffer[i] has destination EntitiesUIDs[RelationshipsTo[i]] else the relationship has been deleted after pathfinding. Note that origin and destination of a relationship may not match origin and destination of the relationship group because the relationship can be traversed backwards.
    Class Represents a Knowledge Graph Relationship Type.
    Class Represents a Knowledge Graph Relationship Type Endpoint.
    Class A Knowledge Graph Time Filter represents a set of time constraints that apply to the "events" of a path.
    Class Defines a window of time.
    Class Represents a Knowledge Graph Filtered Find Paths TraversalDirection. The filtered find paths algorithm uses traversal directions to specify how relationships are traversed. When no traversal direction is defined for a specific relationship type, the default traversal direction is used.
    Class Represents a Knowledge Graph Type which is used as a base class for entity and relationship types.
    Class Represents a Knowledge Graph Type Index. It is primarily used to configure a property of an entity type or a relationship type within the data model visualization view.
    Class Represents a Knowledge Graph Type Property. It is primarily used to configure a property of an entity type or a relationship type within the data model visualization view.
    Class Represents a KML data connection.
    Class Represents a KML layer.
    Class Represents the Centrality computation options for a Knowledge Graph. Several measures of centrality are supported: Degree, Indegree, Outdegree, PageRank, Eigenvector, Coreness, Betweenness, Closeness and Harmonic. These measures fall in two broad categories: degree based measures are Degree, Indegree, Outdegree, PageRank, Eigenvector and Coreness while shortest paths based measures are Betweenness, Closeness and Harmonic. The "importance" relationship weight is taken into account in degree based measures: a relationship with higher importance will increase the centrality scores of nearby related entities. The "cost" relationship weight is taken into account in shortest paths based measures: a relationship with higher cost will decrease the centrality scores of nearby related entities.
    Class Represents a coordinate property value.
    Class Represents a Knowledge Graph data connection.
    Class Represents a Knowledge Graph Data Loading Configuration.
    Class Represents a Knowledge Graph Data Loading Entity.
    Class Represents the options for handling missing data in a Knowledge Graph Data Loading Configuration.
    Class Represents a Knowledge Graph Data Loading Relationship.
    Class Represents a property value from an expression.
    Class Represents a property value from a specific import field.
    Class Represents a fixed string property value.
    Class Represents the ID property value from a specific CIMKnowledgeGraphDataLoadingEntity or CIMKnowledgeGraphDataLoadingRelationship.
    Class Represents a Knowledge Graph Investigation.
    Class Represents a Knowledge Graph Investigation Type Info.
    Class Provides access to properties of a Knowledge Graph layer.
    Class Represents the Centrality computation options in a Knowledge Graph Link Chart. Several measures of centrality are supported: Degree, Indegree, Outdegree, PageRank, Eigenvector, Coreness, Betweenness, Closeness and Harmonic. These measures fall in two broad categories: degree based measures are Degree, Indegree, Outdegree, PageRank, Eigenvector and Coreness while shortest paths based measures are Betweenness, Closeness and Harmonic. The "importance" relationship weight is taken into account in degree based measures: a relationship with higher importance will increase the centrality scores of nearby related entities. The "cost" relationship weight is taken into account in shortest paths based measures: a relationship with higher cost will decrease the centrality scores of nearby related entities.
    Class Represents a Knowledge Graph Link Chart Properties object.
    Class Contains the information defining the multiple type entity lookup.
    ClassBase class for Knowledge Graph named type filters. A named type is either an entity type or a relationship type.
    A named type filter represents some instances (entities or relationships) of the named type, and specifies whether these instances are included or excluded.
    Class Represents a Knowledge Graph named type filter by instances.
    Class Represents a Knowledge Graph named type filter by type with optional property filter predicate.
    Class Represents a Knowledge Graph Data Loading Property used by entities and relationships.
    Class Represents a Knowledge Graph Data Loading Property used for entities and relationships.
    Class Base (indicator) class for all CIMKnowledgeGraphXXXPropertyValue.
    Class Represents a Knowledge Graph Query Definition.
    Class Represents a Knowledge Graph Search Definition.
    Class Represents a Knowledge Graph Search Filter Setting.
    Class Base class for spatial merge operations.
    Class Represents merging geometries by intersection.
    Class Represents merging geometries within a specified distance. The properties define a buffer which is used to perform an intersection. The buffers are always created in the coordinate system of the import data. If the import data has a geographic coordinate system, and the DistanceUnit is a Linear Unit, geodesic buffers will be created. Otherwise, planar buffers will be created.
    Class Represents merging geometries within a specified distance. The properties define a buffer which is used to perform an intersection. The buffers are always created in the coordinate system of the import data. The buffers will always be geodesic, using shape preservation (densification).
    Class Represents a Spatial Knowledge Graph Data Loading Property used for entities. This class is expected to be used only when the Type of property is esriFieldTypeGeometry.
    Class Represents a subgraph of a Knowledge Graph, defined by entity and relationship filters.
    Class Contains the information required to perform an entity lookup on a specific type.
    Class Represents a Knowledge Graph Type Property Info. It is primarily used to configure property visibility within the investigation view.
    Class Contains settings to be used in chronological layout calculations.
    Class Represents a Knowledge Link Chart Layout Info object.
    Class Contains settings to be used in organic layout calculations.
    Class Represents a Knowledge Nonspatial Data Display object.
    Class Represents a color defined in the LAB color space.
    Class Represents a label class which describes how to generate a set of text labels from a group of features in a feature layer.
    Class Represents label class properties.
    Class Represents label placement properties.
    Class Represents internal labels for a MapGrid.
    Class Represents a LAS dataset layer.
    Class Represents a LAS point elevation renderer.
    Class Represents a LAS point splatter.
    Class Represents a LAS stretch class.
    Class Represents LAS stretch input.
    Class Represents a LAS stretch renderer.
    Class Represents a LAS unique value renderer.
    Class Represents a latitude and longitude format.
    Class Represents a layer document which is the document type used for saving .lyrx files.
    Class Represents a layer elevation surface.
    Class Represents a layer property override set.
    Class Represents a layer range.
    Class Represents a layer's scale visibility options.
    Class Represents a layer template.
    Class Represents a layout in a project.
    Class Represents a layout document which is the document type used for saving .pagx files.
    Class Represents a layout view in the project.
    Class Represents the generic base type for leaders.
    Class Represents a leader line.
    Class Represents a leader point.
    Class Represents a legend on a layout.
    Class Represents a legend item.
    Class Represents a custom legend patch, the small lines or rectangles used to display legend classes.
    Class Defines the URI and required field properties for the Indoors Level layer required for floor filtering operations.
    Class Represents a linear continuous color ramp scheme.
    Class Represents a line callout.
    Class Represents line chart media info.
    Class Represents a line graphic.
    Class Represents a line legend patch, small lines used to display legend classes.
    Class Represents a line of sight exploratory analysis definition.
    Class Represents a line symbol which is used to draw polyline features or graphics.
    Class Represents a link chart.
    Class Represents the base definition of a link chart.
    Class Represents a link chart entity.
    Class Represents a Link Chart Feature Layer.
    Class Represents additional settings used by a Link chart field filter.
    Class Represents the link chart filter information.
    Class Represents a group of link chart filters.
    Class Represents the link chart labeling information.
    Class Represents the link chart link drawing information.
    Class Represents the link chart link labeling information.
    Class Represents the link chart node drawing information.
    Class Represents the link chart node labeling information.
    Class Represents additional settings used by a Link chart property filter.
    Class Represents a link chart relationship.
    Class Represents the link chart viewport.
    Class Represents a location condition.
    Class Represents properties of locator for the map.
    Class Represents a map or scene.
    Class Represents a map document which is the document type used for saving .mapx files.
    Class Represents a map frame on a page layout.
    Class Represents geotrigger properties for a map.
    Class Represents a grid object for a map frame.
    Class Represents a map grid edge.
    Class Represents an ArcGIS Map Service layer.
    Class Represents a Maplex dictionary.
    Class Represents a Maplex dictionary entry.
    Class Represents Maplex external zone priorities.
    Class Represents Maplex general placement properties.
    Class Represents Maplex internal zone priorities.
    Class Represents a Maplex key number group.
    Class Represents Maplex label placement properties.
    Class Represents Maplex label stacking properties.
    Class Represents Maplex offset along the line properties.
    Class Represents Maplex rotation properties.
    Class Represents a Maplex stacking separator.
    Class Represents Maplex strategy priorities.
    Class Represents a map presentation page.
    Class Represents the Guide to Numbered (GNF) surround element.
    Class Represents how a grid reference (MGRS) should be displayed within CIMMapProductGridStreetIndex.
    Class Represents a street index that calculates the grid reference (MGRS) of each street in surround element.
    Class The base class for layout surround elements used in producing map products based on industry specifications.
    Class The Map series object represents a means to create multi-page PDF or based off of fields in the index layer.
    Class Represents map stereo properties.
    Class Represents a map surround on a page layout.
    Class Represents a map table view in the project.
    Class Represents map time display.
    Class Represents a map view in the project.
    Class Represents a margin to apply around the page.
    Class Represents a marker which is a self-contained shape or image that can draw for a point graphic or placed in a repeating arrangement along a stroke or within a fill. It can be a glyph from a font, a picture, a collection of vector geometries, or a 3D model.
    Class Represents a marker fill placement.
    Class Represents a marker graphic which is used to define vector graphics in a vector marker.
    Class Represents a marker north arrow on a page layout.
    Class Represents a marker placement.
    Class Represents marker placement along the line which defines how a marker is placed along a line or polygon outline.
    Class Represents marker placement along the line which places randomly sized markers evenly along a line or polygon outline.
    Class Represents marker placement along the line which places markers that are the same size evenly along a line or polygon outline.
    Class Represents marker placement along the line which places markers in either increasing, decreasing or alternating gradations along a line or polygon outline.
    Class Represents marker placement around polygon which places a marker on a specific position on the polygon outline.
    Class Represents marker placement at extremities which places markers at only one or both endpoints of a line.
    Class Represents marker placement at geometry M values.
    Class Represents marker placement at ratio positions which places a set number of markers along the line or the outline of a polygon.
    Class Represents marker placement inside a polygon which defines how a polygon is filled with a pattern of markers.
    Class Represents a marker placement on the line.
    Class Represents a marker placement on vertices which places a single marker on a line or polygon outline at a set distance from the middle or one of the endpoints.
    Class Represents marker placement polygon center which defines how a single marker will be placed within the polygon.
    Class Represents a marker stroke placement.
    Class Properties relevant to query layers based on materialized views.
    Class Represents a material which defines how the multipatch or mesh is drawn.
    Class Represents a measured grid of the mapFrame.
    Class Represents media info.
    Class Represents a stroke drawn at specified edges of a mesh.
    Class Represents a mesh symbol which is used to draw multipatch features or mesh features.
    Class Provides a set of instructions and examples that enable users to compose standard grid reference.
    Class Defines the display properties of the meter reference guide.
    Class Represents a gridLine to draw the 100,000 MGRS grids.
    Class Represents module settings in the project.
    Class Represents a visual effect for reshading the scene to monochromatic tones.
    Class Represents a mosaic layer corresponding to a mosaic dataset.
    Class Represents a mosaic rule.
    Class Represents a multilayer symbol, a generic type for point, line, and polygon symbols, specifying that they can contain more than one symbol layers.
    Class Represents a color visual variable with different levels-of-detail.
    Class Represents a visual variable with different levels-of-detail, each with its own minimum and maximum data values. Used for binning layers.
    Class Represents a multipart color ramp scheme.
    Class Represents a multipatch feature template.
    Class Represents a multipatch feature template model.
    Class Represents a shape graphic with a MultiPatch geometry.
    Class Represents a shape graphic with a Multipoint geometry.
    Class Provides access to members that control multi series chart properties.
    Class Represents a network analysis layer.
    Class Represents locator settings for a particular class.
    Class Represents a nested legend item in a legend.
    Class Represents a NetCDF raster data connection.
    Class Represents a NetCDF standard data connection.
    Class Provides access to read or update the value assigned to a network parameter of a network attribute.
    Class Represents a network dataset element composite renderer.
    Class Represents a network dataset layer.
    Class Represents a network dataset renderer.
    Class Represents a network dataset simple renderer.
    Class Represents a network dataset traffic renderer.
    Class Represents a network source display filter.
    Class Represents a Trace Configuration.
    Class The network travel mode is used to configure a group of cost, traversability, and other analysis configurations.
    Class Specifies the travel mode travel mode to be applied. Depending on the SourceType, some properties are conditionally required to indicate the travel mode.
    Class Represents a NITF data connection.
    Class Represents NITF feature sub layer.
    Class Represents NITF group sub layer.
    Class Represents NITF image sub layer.
    Class Represents a NITF composite layer.
    Class Represents NITF screen overlay.
    Class Represents a north arrow on a page layout.
    Class Represents a number format.
    Class Represents a numeric format.
    Class Represents the numeric format base class.
    Class Represents the base CIM object class.
    Class Represents a 3D object rendering filter.
    Class Represents a filter authoring info.
    Class Represents a 3D object rendering filter block.
    Class Represents a filter block authoring info.
    Class Represents a 3D object rendering filter value.
    Class Represents a OGC API Map Tiles service connection.
    Class Represents a OGCAPI service connection.
    Class Represents an oriented imagery layer.
    Class Represents a visual effect for reshading the scene with outlines.
    Class Represents the page information associated with a layout.
    Class Represents page definition.
    Class Represents a pansharpening filter.
    Class Represents a paragraph text graphic.
    Class Defines the parcel fabric active record properties needed for record-driven parcel workflows.
    Class Represents a parcel fabric layer.
    Class Represents a visual effect for reshading the scene with a pencil sketch style.
    Class Represents a percentage format.
    Class Represents a picture fill which fills polygonal geometry with a picture. Supported file types are .bmp, .jpg, .png, and .gif.
    Class Represents a picture graphic.
    Class Represents a picture marker created from a raster (bitmapped) image file. The image can have color substitutions to replace one or more colors in the image or it can have a tint applied to the whole image depending on the picture type. Supported formats are .bmp, .jpg, .png, and .gif.
    Class Represents a picture stroke which draws linear geometry with a repeating image file. Supported file types are .bmp, .jpg, .png, and .gif.
    Class Represents a pie chart marker which is a marker that draws numeric values arranged in a circle.
    Class Represents pie chart media info.
    Class Represents a visual effect for reshading the scene with a pixelated style.
    Class Represents a point cloud algorithm.
    Class Represents a point cloud bit field filter. Filters based on the bit-wise representation of the provided field. /// For a point to be retained, its attribute field bits must match /// BitsToSet and BitsToClear. Bits which are not explicitly clear nor /// set, are ignored.
    Class Represents a point cloud class breaks renderer.
    Class Represents a point cloud filter.
    Class Represents a point cloud fixed size algorithm.
    Class Represents a point cloud layer.
    Class Represents a point cloud renderer.
    Class Represents a point cloud return filter.
    Class Represents a point cloud RGB renderer.
    Class Represents a point cloud splat algorithm.
    Class Represents a point cloud stretch renderer.
    Class Represents a point cloud unique value renderer.
    Class Represents a point cloud value filter. Filter points based on the value of an specified attribute.
    Class Represents a point graphic.
    Class Represents a point symbol used to draw point features and point graphics.
    Class Represents a point symbol callout which draws a point symbol as the background and a line symbol for leaders. Often used for highway shields.
    Class Represents a polar continuous color ramp scheme.
    Class Represents a polygon graphic.
    Class Represents a polygon symbol which is used to draw polygon features or polygon graphics.
    Class Represents a pop-up field description.
    Class Represents pop-up info.
    Class Represents a grid layout for pop-up media infos.
    Class Represents pop-up utility network association.
    Class Represents a reference to a portal item.
    Class Represents a post-processing effect definition to be applied to a 3D view.
    Class Represents a presentation.
    Class Represents a presentation document which is the document type used for saving .prsx files.
    Class Presentation map gravity well resting state.
    Class Represents a presentation layer property override set.
    Class Presentation map resting state.
    Class Represents a map view in a map presentation page.
    Class Represents a presentation page.
    Class Presentation map rotate resting state.
    Class Represents a transition.
    Class Represents a primitive override.
    Class Represents the printer preferences associated with a layout.
    Class Represents a procedural symbol layer which defines rendering using script-based logic to construct complex 3D objects and textures from simple geometries. Properties of the symbol are derived from a rule package (.rpk file).
    Class Layout element used to draw Profile view of Runway, Terrain, obstacles and Obstruction Identification Surfaces (OIS).
    Class Grid shown for the profile.
    Class Represents common properties for all the obstacles.
    Class Defines the properties for OIS features.
    Class Defines the properties for a Point obstacle.
    Class Represents a profile poly obstacle.
    Class Display properties for Runway.
    Class Display properties for Terrain.
    Class Settings to control how the terrain information is being displayed in the profile.
    Class Represents an item in the project.
    Class Represents a project server connection.
    Class A collection of options governing project thumbnail generation.
    Class Represents proportional pie size options.
    Class Represents a proportional renderer.
    Class Represents additional authoring properties used by a proportional renderer.
    Class Represents a rainy weather effect to be applied to a scene.
    Class Represents a random HSV color ramp scheme.
    Class Represents a range.
    Class Represents a range definition.
    Class Represents a range dimension name and value pair used to define the multidimensional display definition for the current display slice.
    Class Represents a range variable.
    Class Represents a raster band data connection.
    Class Represents a raster class break.
    Class Represents a raster classify colorizer.
    Class Represents a raster CMYK colorizer.
    Class Represents a raster color correction configuration.
    Class Represents a raster colorizer.
    Class Represents a raster colorizer mapping.
    Class Represents a raster color map colorizer.
    Class Represents a set of criteria used to define the multidimensional extent of a raster layer.
    Class Represents a raster discrete color colorizer.
    Class Represents raster histogram custom stretch edit info.
    Class Represents a raster layer which displays raster imagery stored in a raster dataset.
    Class Represents a multidimensional display definition for the current display slice.
    Class Represents a multidimensional extent applicable to a raster layer.
    Class Represents a raster RGB colorizer.
    Class Represents a raster shaded relief colorizer.
    Class Represents a raster stretch class.
    Class Represents a raster stretch colorizer.
    Class Represents a raster table.
    Class Represents a raster unique value class.
    Class Represents a raster unique value colorizer.
    Class Represents a raster unique value group.
    Class Represents a raster vector field colorizer.
    Class Provides access to properties of a rate duration.
    Class Represents a rate format.
    Class Defines a reference grid.
    Class Defines the label template for the reference grids.
    Class Represents a Related Report section of a report.
    Class Represents relate info.
    Class Represents relate base.
    Class Represents relationship media info.
    Class Represents a RelQuery table data connection.
    Class Represents a renderer.
    Class Represents additional authoring properties used by a renderer.
    Class Represents a raster rendering rule.
    Class Represents a report in a project.
    Class Represents the data source properties of a report. The data source can be a map member or external data.
    Class Represents a details section of a report.
    Class Represents a report document which is the document type used for saving .rlfx files.
    Class Represents field properties that will be applied to an element in a report.
    Class Represents a field in a report.
    Class Represents a report footer in a report.
    Class Represents a report header section in a report.
    Class Represents a layout supplemental page section of a report.
    Class Represents properties that will be applied to a map frame element in a report.
    Class Represents a page footer in a report.
    Class Represents a page header section in a report.
    Class Represents a supplemental page section of a report.
    Class Gets or sets the data source for a report.
    Class Represents a section of elements in a report.
    Class Represents a watermark in a report.
    Class Represents a representation renderer.
    Class Represents a renderer that shows the restriction status of network elements.
    Class Restriction status, label, and symbol.
    Class Represents a color in the RGB color model.
    Class Represents a rotation visual variable.
    Class Represents a route event data connection.
    Class Represents a row template.
    Class Represents rule symbol layer names.
    Class Represents S-101 portrayal settings.
    Class Represents S-52 display settings.
    Class Represents S-52 mariner settings object for controlling the drawing of ENC layers.
    Class Represents S-52 text group settings.
    Class Represents S-52 viewing group properties object.
    Class Represents a 2D scale or 3D Distance.
    Class Represents a scale bar on a page layout.
    Class Represents the scale dependent size variations for a symbol reference.
    Class Represents the scale formatting options.
    Class Represents a Scale line on a page layout.
    Class Represents a scene data connection.
    Class Represents scientific number format.
    Class Business Analyst segmentation profile. Segmentation profile represents distribution of the market (e.g. people or households) between the segments of the segmentation system. For example, it could represent the distribution of the customer base between the segments. Segmentation profile can include the volumetric information in addition to the counts, e.g. it could also provide the distribution of the sales between segments.
    Class Represents a document used for saving segmentation profile.
    Class Business Analyst segmentation target. Target is a collection of market segments that are treated as a whole. A user might apply the same marketing strategy to all segments in a target, for example.
    Class Business Analyst target group. Target group represents a collection of targets.
    Class Represents a document used for saving target group.
    Class Visualization properties of Business Analyst Segmentation target group.
    Class Represents a server connection.
    Class Represents a service composite sublayer.
    Class Represents a service connection.
    Class Represents a service layer.
    Class Represents a service sublayer.
    Class Represents a service subtable.
    Class Represents a shape graphic, the generic base class for geometry based graphics.
    Class Represents a shape vertex.
    Class Represents shape vertices.
    Class Represents a simple format for a label.
    Class Represents a simple line callout for drawing basic leader lines.
    Class Represents a simple renderer.
    Class Provides access to properties of a simulation layer.
    Class Represents and single fill scale bar on a page layout.
    Class Defines the URI and required field properties for the Indoors Site layer required for floor filtering operations.
    Class Represents a classified size visual variable.
    Class Represents a size visual variable.
    Class Represents a slice cylinder exploratory analysis definition.
    Class Represents a slice plane exploratory analysis definition.
    Class Represents a slice sphere exploratory analysis definition.
    Class Represents slider settings.
    Class A slope guide surround element which is used to ascertaining terrain slope graphically /// as a percentage and a gradient (degree).
    Class Represents snapping properties.
    Class Represents a snowy weather effect to be applied to a scene.
    Class Represents a solid fill which fills polygonal geometry with a single solid color.
    Class Represents a stroke drawn at specified edges of a mesh using solid color.
    Class Represents a solid stroke which draws linear geometry with a single solid color.
    Class Spatial Map Series is a means to create a series of map pages based /// off of spatial features.
    Class Represents a spot color.
    Class Represents a color space for spot colors.
    Class Represents a SQL query data connection.
    Class Represents a stacked bar chart marker which is a chart made of vertical stacked bars displaying values.
    Class Represents a standalone table.
    Class Represents a standalone video.
    Class Represents a standard data connection, the most common data connection type.
    Class Represents standard label engine general placement properties.
    Class Represents standard label engine label placement properties.
    Class Represents standard label engine line label position.
    Class Represents standard label engine line label priorities.
    Class Represents standard label engine point placement priorities.
    Class Represents a standard service connection.
    Class A statistical data collection is used by the Business Analyst to organize and present data that can be aggregated by the enrich functionality. This is not the storage of the data, it is metadata about the data that describes how data will be aggregated by Business Analyst. Currently, data can be calculated by defining what data collections and analysis variables are needed in the output for a given input features.
    Class Base class for statistical data collection calculator.
    Class Represents a document used for saving statistical data collections.
    Class Statistical data collection calculator based on a feature layer.
    Class Represents a field of a statistical data collection that matches to existing field in referenced feature dataset.
    Class Represents the property used to calculate the geodesic area of the input feature.
    Class Statistical Data Collection calculator for accessing properties of input features, e.g. Area of polygonal input.
    Class Represents a property of an input feature.
    Class Statistical data collection calculator based on a scripts that use fields from other calculators.
    Class Statistical data collection calculator based on a standard local data.
    Class Represents a field of a statistical data collection that matches to an existing variable in referenced feature dataset.
    Class Represents a stream service data connection.
    Class Represents a string map of key value pairs.
    Class Represents a stroke which defines how line geometry or the outline of polygon geometry is drawn.
    Class Represents sublayer.
    Class Represents sublayer base class.
    Class Represents a subtype group layer that works with feature classes enabled with subtypes.
    Class Represents a subtype layer base class that works with feature classes enabled with subtypes.
    Class Represents a subtype group table that works with tables enabled with subtypes.
    Class Represents a sunny weather effect to be applied to a scene.
    Class Represents suppress activity.
    Class Represents a stylized rendering effect that is applied to a surface in a 3D view.
    Class Represents a symbol. A symbol is used to describe how a geometric shape, such as that from a graphic or feature, is displayed.
    Class Represents an animation of a symbol, this is the base class for all animations.
    Class Represents the color animation.
    Class Represents the offset animation.
    Class Represents the rotation animation.
    Class Represents the scale animation.
    Class Represents the size animation.
    Class Represents the transparency animation.
    Class Represents a symbol identifier.
    Class Represents a symbol layer. Symbol layers are the components that make up a symbol. A symbol layer is represented by a stroke, fill, marker, or procedural symbol layer.
    Class Represents symbol layer drawing properties.
    Class Represents symbol layer identifier.
    Class Represents symbol layer masking.
    Class Represents a symbol reference.
    Class Defines a tab for a MapGrid.
    Class Represents properties for a table field.
    Class Layout element used to display tabular data.
    Class Display properties for fields in a table frame.
    Class Represents table media info.
    Class Represents a table query name data connection.
    Class Represents a table view in the project.
    Class Represents a temporal data connection.
    Class Represents a terrain attribute renderer.
    Class Represents a terrain dirty area renderer.
    Class Represents a terrain layer.
    Class Represents a terrain point attribute graduated renderer.
    Class Represents a terrain point attribute unique renderer.
    Class Represents a terrain point elevation renderer.
    Class Represents a text graphic.
    Class Represents a text graphic base class, the generic base class for text based graphics.
    Class Represents a text margin which defines the margin to apply around text.
    Class Represents text media info.
    Class Represents a text symbol which is used to draw text graphics, bleeds, and annotation. Text symbols do not contain any symbol layers but can have callouts.
    Class Represents a tick of a grid.
    Class Represents a tiled service layer.
    Class Represents a 3D Tiles data connection.
    Class Represents a 3D Tiles layer.
    Class Represents the data for simulating camera tilt-shift effect for creating a miniaturization effect in 3D scenes.
    Class Represents a time data definition.
    Class Represents a time dimension definition.
    Class Represents a time display definition.
    Class Represents a timeline.
    Class Represents a source of temporal data.
    Class Represents the timeline lane drawing information.
    Class Represents a map member source of temporal data.
    Class Represents a layer in a timeline.
    Class Represents a swimlane in a timeline.
    Class Represents a time table definition.
    Class Represents a TIN breakline renderer.
    Class Represents a TIN color ramp renderer.
    Class Represents a TIN contour renderer.
    Class Represents a TIN edge renderer.
    Class Represents a TIN face class breaks renderer.
    Class Represents a TIN face renderer.
    Class Represents a TIN face value renderer.
    Class Represents a TIN layer which displays TIN data sources, a data structure that represents terrain data as a triangulated irregular network.
    Class Represents a TIN node elevation renderer.
    Class Represents a TIN node renderer.
    Class Represents a TIN node value renderer.
    Class Represents a TIN renderer.
    Class Represents a TIN simple renderer.
    Class Represents a TIN unique value renderer.
    Class Represents TM Elevation Guide Bar surround element.
    Class Represents a visual effect for reshading the scene with a cartoon style.
    Class Represents a compass rose north arrow which displays declination with a compass dial.
    Class Represents a topology dataset as a layer and draws its errors, exceptions, and areas in need of validation.
    Class Represents a topographic north arrow which displays declination of true, grid and magnetic north.
    Class Represents a trace network layer.
    Class Represents a tracking server data connection.
    Class Represents a trajectory layer corresponding to a trajectory dataset.
    Class Represents a transparency visual variable.
    Class Traversable directions, label, and adorner point symbol. The applicable adorner point symbol is oriented and added to the restriction status symbol when drawn to indicate the directional traversability of network elements.
    Class Represents a unique value.
    Class Represents a unique value class.
    Class Represents a unique value group.
    Class Represents a unique value renderer.
    Class Represents additional authoring properties used by a unique value renderer.
    Class Represents unit symbolization.
    Class Represents utility network associations media info.
    Class Represents a utility network layer.
    Class Represents a vector marker which can represent vector graphics. It's constructed from MarkerGraphics which are geometries and symbols used as building blocks for the marker.
    Class Represents a VectorTile layer data connection.
    Class Represents a VectorTile layer.
    Class Represents a version object used for representing the saved version.
    Class Represents a vertical legend item in a legend.
    Class Represents a video data connection.
    Class Represents video-related graphic being displayed on the map.
    Class Represents an video media presentation page.
    Class Represents an event indicator on a video timeline.
    Class Represents an indicator on a video timeline.
    Class Represents a range indicator on a video timeline.
    Class Represents a view in the project.
    Class Represents a view camera.
    Class Represents a view dome exploratory analysis definition.
    Class Represents a view keyframe.
    Class Represents a viewshed exploratory analysis definition.
    Class Represents a animation view track.
    Class Represents a post-processing technique that reshades the scene with a vignette effect.
    Class Represents a visual effect definition for stylized rendering of all the content in a map or scene.
    Class Represents a visual variable.
    Class Represents visual variable metadata used for authoring.
    Class Represents visual variable info.
    Class Represents a level-of-detail for a multilevel visual variable.
    Class Represents a voxel color unique value.
    Class Represents a voxel data connection.
    Class Represents a renderer filter.
    Class Represents a voxel format.
    Class Represents a voxel layer.
    Class Represents voxel lighting.
    Class Represents a voxel plane.
    Class Represents a voxel value filter. Filter based on the value of an specified variable.
    Class Represents a voxel renderer.
    Class Represents a voxel static section.
    Class Represents a stretch renderer.
    Class Represents a voxel layer variable profile.
    Class Represents a voxel layer volume.
    Class Represents a visual effect for reshading the scene with a watercolor style.
    Class Represents a water fill which fills polygonal geometry with animated water.
    Class Represents a WCS service connection.
    Class Represents a weather effect to be applied to a scene.
    Class Represents a WFS service connection.
    Class Represents an OGC WMS layer.
    Class Represents a WMS service connection.
    Class Represents a WMS service sublayer.
    Class Represents a WMTS service connection.
    Class Represents a workspace connection.
    Class Represents an XY event data connection.
    Class Represents a color in the XYZ color model.
    Class A collection of settings that control JSON deserialization.
    Class A collection of settings that control JSON serialization.
    Class Las filter.
    Class Represents a generic network analyst agent. This class is reserved for esri internal use only.
    Class Represents a generic network analyst agent definition. This class is reserved for esri internal use only.
    Class Represents a network attribute parameter value. This class is reserved for esri internal use only.
    Class Represents a closest facility solver. This class is reserved for esri internal use only.
    Class Represents a network analyst compact street directions agent. This class is reserved for esri internal use only.
    Class Represents a solver definition that can support directions configurations. This class is reserved for esri internal use only.
    Class Represents a last mile delivery fleet solver. This class is reserved for esri internal use only.
    Class Represents a location-allocation solver. This class is reserved for esri internal use only.
    Class Represent a network analyst locator. This class is reserved for esri internal use only.
    Class Represents a network analyst locator agent. This class is reserved for esri internal use only.
    Class Represents a network analyst locator definition. This class is reserved for esri internal use only.
    Class Represents a network analyst locator feature agent. This class is reserved for esri internal use only.
    Class Represents a network analyst locator location fields agent. This class is reserved for esri internal use only.
    Class Represents an origin-destination cost matrix solver. This class is reserved for esri internal use only.
    Class Represents a route solver. This class is reserved for esri internal use only.
    Class Represents a service area solver. This class is reserved for esri internal use only.
    Class Represents a solver definition. This class is reserved for esri internal use only.
    Class Represents a network analyst street directions agent. This class is reserved for esri internal use only.
    Class Represents a network analyst street directions agent definition. This class is reserved for esri internal use only.
    Class Represents a vehicle routing problem solver. This class is reserved for esri internal use only.
    Class Represents a waste collection fleet solver. This class is reserved for esri internal use only.
    Class Represents a network travel mode. This class is reserved for esri internal use only.
    Class Represents a network travel mode parameter value. This class is reserved for esri internal use only.
    Class Raster color map.
    Class Provides static methods that can be used for JSON and XML serialization and deserialization.
    Class Represents a raster statistics and histogram class.
    Class Represents an extent of time defined by a start and end date.
    Class Represents an instant in time. The time has no duration.
    Class Represents the time zone definition for a given date and time.
    Class Represents a timestamp plus an offset in hours and/or minutes.
    ClassRepresents the base class for TimeExtent and TimeInstant.
    Class Contains a utility for reading a CIMObject from an XML string.
    Interfaces
     InterfaceDescription
    Interface Provides a mechanism for accessing and setting properties of feature layers
    Enumerations
     EnumerationDescription
    Enumeration Relative to the ground.
    Enumeration A list of anchor positions for an element on a page layout.
    Enumeration Angle alignment types.
    Enumeration Represents the easing options for an animated symbol.
    Enumeration Represents the ways an animated symbol can be repeated.
    Enumeration Options to control how the animation color combines with symbol layer colors.
    Enumeration Specifies the method of transition for a value in a keyframe.
    Enumeration Attachment display types.
    Enumeration Represents the attachment filter type. The filter attachment type determines which attachments from the feature are shown in the exported report.
    Enumeration A list of the advanced map frame options that further controls the camera behavior.
    Enumeration A list of the options available when using a fixed constraint.
    Enumeration Specifies a type of the Above and Below benchmark style.
    Enumeration Specifies a type of the Highlight Extremes benchmark style.
    Enumeration Specifies options for setting a benchmark. Site attributes and variables for the input features are compared against the benchmark.
    Enumeration Specifies the colors used in the results table fields to show differences from the benchmark.
    Enumeration Specifies a type of the Top and Bottom benchmark style.
    Enumeration Represents Color Coded Layer boundary type.
    Enumeration Specifies the status of the level of detail.
    Enumeration Represents Suitability Analysis combination method.
    Enumeration Represents Suitability Analysis criterion influence.
    Enumeration Represents Suitability Analysis final score scale method.
    Enumeration Represents histogram chart subset selection methods.
    Enumeration Balloon callout styles.
    Enumeration Represents Suitability Analysis point layer based criterion type. Defines the type of spatial relationship to be used as criteria.
    Enumeration Represents Suitability Analysis point layer based criterion statistics type. The type of statistical operation to be applied to the weighted field.
    Enumeration Represents Suitability Analysis preprocessing method.
    Enumeration Represents Suitability Analysis preset method.
    Enumeration Weights for symbols that are used as barriers to labeling.
    Enumeration Represents scatterplot chart types.
    Enumeration A list of base elevation types.
    Enumeration Represents variable value type.
    Enumeration A list of different billboard modes.
    Enumeration Bind variable types.
    Enumeration A threshold for determining when binned features should be shown as points.
    Enumeration Bivariate grid label strategy.
    Enumeration Bivariate grid orientation type.
    Enumeration Bivariate grid size option.
    Enumeration Blending modes.
    Enumeration Block progressions.
    Enumeration Defines a kind of centrality measure.
    Enumeration Specifies the way relationships are interpreted for centrality computations.
    Enumeration Specifies the normalization option for centrality scores.
    Enumeration CGA attribute type.
    Enumeration Options for choosing what aggregation type is to be used while calculating values.
    Enumeration Provides a type of coloring that chart series uses.
    Enumeration Types of a data transformation to apply before calculating histogram bins and counts.
    Enumeration Represents the temporal profile plot type.
    Enumeration Chart font weight types.
    Enumeration Specifies the type of guide.
    Enumeration Chart legend alignment options.
    Enumeration Chart line dash style.
    Enumeration Provides a choice of how map selection is processed in the chart.
    Enumeration Chart marker symbol style.
    Enumeration Standard multiple bar series placement options.
    Enumeration Options to handle null values.
    Enumeration Specifies the position of the content for a target.
    Enumeration Chart probability plot types.
    Enumeration Grid Scatter plots display options.
    Enumeration Chart sort direction.
    Enumeration Scatter plot matrix diagonal display options.
    Enumeration Scatter plot matrix display options.
    Enumeration Scatter plot matrix sort-by type.
    Enumeration Chart multiple series stacking type.
    Enumeration Represents the surface profile plot type.
    Enumeration Options for choosing text cases for charts.
    Enumeration Options for choosing how time intervals are built for the aggregation of a time based X-axis field.
    Enumeration Represents the trajectory profile plot type.
    Enumeration A fit type for a trend line.
    Enumeration Represents the type of chart.
    Enumeration Specifies the type of value.
    Enumeration Legend display options for class breaks visual variables.
    Enumeration Types of class break renderer.
    Enumeration Methods used for classifying numerical fields for graduated symbology.
    Enumeration Specifies the clipping mode used for the map.
    Enumeration Clipping types.
    Enumeration A list of color balance methods.
    Enumeration Indicates the target color channel overridden by the class breaks color visual variable.
    Enumeration A list of color correction stretch types.
    Enumeration A list of hillshade types for colorizer.
    Enumeration A list of scaling types for colorizer.
    Enumeration A list of color matching methods.
    Enumeration Specifies color model used for maps and layouts.
    Enumeration Specifies color spaces used for colors.
    Enumeration Color vision deficiency types.
    Enumeration A list of column layouts.
    Enumeration Query builder comparison operator between fields.
    Enumeration Defines the type of condensed tab.
    Enumeration Connection modes.
    Enumeration Represents a type of contiguous tabs.
    Enumeration A list of Cruising Altitude Diagram types.
    Enumeration Represents the direction for clipping.
    Enumeration Source filter to update the statistics.
    Enumeration Data engineering statistic type.
    Enumeration Treat Field as Type.
    Enumeration Statistic View Layout Type.
    Enumeration Data normalization methods.
    Enumeration Field search modes.
    Enumeration Defines which direction declination will be calculated from.
    Enumeration Represents the kernel sizes for depth of field camera effect.
    Enumeration Dimension marker fit options.
    Enumeration Dimension part options.
    Enumeration Dimension text fit options.
    Enumeration Dimension text options.
    Enumeration Dimension types supported by dimension features.
    Enumeration Direction format options.
    Enumeration Direction type.
    Enumeration Direction units.
    Enumeration Represents the discipline type of a building layer.
    Enumeration Display cache types.
    Enumeration DisplayFilterType.
    Enumeration Specifies the dominant size axis types.
    Enumeration A list of the styles available for a double file scale bar.
    Enumeration Defines the capture mode used to specify new Z values when creating or modifying features.
    Enumeration Specifies the types of elevation surfaces.
    Enumeration Units for measuring emission rate.
    Enumeration Enumerates which end a component is visible.
    Enumeration Represents the selection of endPoints.
    Enumeration Define the type of algorithm used to calculate transitions between animation camera keyframes.
    Enumeration Types of attribute rules.
    Enumeration Antialiasing modes.
    Enumeration Text antialiasing.
    Enumeration Dataset type constants.
    Enumeration Types of summary statistic that can be applied to records in a dataset.
    Enumeration Network directions output type.
    Enumeration Feature types.
    Enumeration Field types.
    Enumeration The available kinds of geometry objects.
    Enumeration Image formats.
    Enumeration Join types.
    Enumeration Options for stop collection mode (waste collection solver).
    Enumeration Date-Time Synchronize usage types.
    Enumeration Location-Allocation impedance transformation type
    Enumeration Problem types for the Location-Allocation solver
    Enumeration OD cost matrix type.
    Enumeration Options for service area line results.
    Enumeration Options for service area polygon results.
    Enumeration Time of day usage type.
    Enumeration Options for traveling to or from the facility.
    Enumeration Units of a network dataset attribute.
    Enumeration Policy on when to return the from-edge in the network forward star adjacencies object.
    Enumeration Number format alignment options.
    Enumeration Relationship Cardinality.
    Enumeration Number format rounding options.
    Enumeration Spatial Filter Search Order.
    Enumeration Queryable spatial relationships.
    Enumeration Time relation types.
    Enumeration Time units.
    Enumeration Specifies whether to apply a forward or reverse (inverse) transformation.
    Enumeration Measurement units.
    Enumeration Represents how events ticks are displayed.
    Enumeration Represents the exaggeration modes.
    Enumeration Return types for Arcade expressions.
    Enumeration Extent fit types.
    Enumeration Future implementation.
    Enumeration Options to control how material combines with externally defined colors.
    Enumeration Extremity placement options which specify at which ends of the line a marker will be placed.
    Enumeration The types of extrusion.
    Enumeration The types of face culling.
    Enumeration Feature cache type options.
    Enumeration Stream service feature expiration method.
    Enumeration A list of types of features to label.
    Enumeration Describes Filtered Find Paths configuration warnings.
    Enumeration Describes Filtered Find Paths execution warnings.
    Enumeration Represents the sort information for a field.
    Enumeration Represents field statistics.
    Enumeration Fill modes.
    Enumeration Specifies how origin/destination entities are used in the filtered find paths algorithm.
    Enumeration Specifies the arrangement type for fixed color ramp.
    Enumeration Calibration mode presets.
    Enumeration Culvert profile type.
    Enumeration Value range types for playing flood simulation.
    Enumeration Water display types for playing flood simulation.
    Enumeration Represents the rank or "level" at which the layer participates in filtering for Indoors or floor-aware layers.
    Enumeration Available floor visibility modes for 3D floor aware scenes.
    Enumeration A list of flow representation types.
    Enumeration Font effects.
    Enumeration Font encodings.
    Enumeration Font types.
    Enumeration Enumerates the attachment association types.
    Enumeration Enumerates the ways an element may acquire its value.
    Enumeration Enumerates the initial states for group elements.
    Enumeration Enumerates the ways related records may be displayed.
    Enumeration Enumerates the ways text may be formatted.
    Enumeration Enumerates time resolutions.
    Enumeration Fraction options.
    Enumeration Rules to indicate whether a fence polygon has been entered or exited by the geometry from a feed.
    Enumeration Indicates the type of event that will trigger notifications for the Fence Geotrigger.
    Enumeration Geometric effect arrow types.
    Enumeration Specifies the rules to transform the input ground control points given as a line.
    Enumeration Geometric effect donut methods.
    Enumeration Geometric effect enclosing polygon methods.
    Enumeration Geometric effect extension origins. Specifies the origin of the extension to add to the line. The beginning and end of the line is defined by the direction the line was digitized.
    Enumeration Geometric effect localizer feather styles.
    Enumeration Geometric effect offset method which specifies the way the strokes or fills are displayed at corners.
    Enumeration Geometric effect offset options which specify the way the symbol handles complex geometries.
    Enumeration Geometric effect offset tangent methods which specify the origin of the tangent offset for the line. The beginning and end of the lines are defined by how the line was digitized.
    Enumeration Geometric effect offset waveforms.
    Enumeration Indicates how the geotrigger will use accuracy information from a feed.
    Enumeration Glyph hinting options.
    Enumeration Gradient alignment types.
    Enumeration Describes the gradient fill method which is how the gradient is applied.
    Enumeration The different methods of gradient strokes.
    Enumeration Gradient stroke types.
    Enumeration The type of component of the grid.
    Enumeration Represents the position at which the ladder labels are drawn.
    Enumeration Represents the orientation of the grid line.
    Enumeration List of precision levels for Military Grid Reference System (MGRS).
    Enumeration Defines modes for specifying Scale for ground to grid corrections.
    Enumeration Horizontal alignment types.
    Enumeration HTML pop-up styles.
    Enumeration Illumination source types.
    Enumeration Indexed scene layer types.
    Enumeration Query builder Boolean operator types.
    Enumeration The closed path policy, i.e whether we allow, forbid, or require that result paths are closed. A path is closed when the start and end vertices of the path are the same.
    Enumeration Defines the behaviour when a durative event has a missing start or end time.
    Enumeration Defines the behaviour when a durative event start time is after the end time.
    Enumeration Defines the behaviour when a punctual or durative event has no time.
    Enumeration Specifies the filter type.
    Enumeration Specifies the behavior when merge properties have missing data.
    Enumeration Defines the behaviour when a strictly negative cost is found, and only positive costs are supported.
    Enumeration Specifies whether the path filter is applied to an entity/entity type or a relationship/relationship type.
    Enumeration Specifies the filter type of a path filter used in filtered find paths.
    Enumeration Describes errors related to the time value(s) of a time event.
    Enumeration Specifies whether the filtered find paths algorithm searches for all paths or only the shortest paths.
    Enumeration Specifies the direction of time along the path.
    Enumeration Specifies relationships traversal directions in the filtered find paths algorithm.
    Enumeration Specifies the scope to restrict search.
    Enumeration Specifies a Knowledge Link Chart layout algorithm.
    Enumeration Specifies a Knowledge Nonspatial Data Display Mode.
    Enumeration Label expression engine types.
    Enumeration The label feature types.
    Enumeration LAS point sizing methods.
    Enumeration LAS stretch attributes.
    Enumeration LAS stretch drawing type.
    Enumeration LAS stretch statistic types.
    Enumeration LAS stretch types.
    Enumeration The style of line to generate when a leader is drawn defined by an enumeration value. Line leaders will always be drawn with their own geometry.
    Enumeration A list of leader types for extent indicators.
    Enumeration A list of legend fitting strategies.
    Enumeration A list of legend item arrangement options.
    Enumeration A list of choices for keeping legend parts together.
    Enumeration The types of lighting.
    Enumeration The style of stroke ending caps.
    Enumeration Determines how the strokes with dash patterns and other patterns (tiled pictures, placement effects) are handled at the end points of the line geometry's segments.
    Enumeration Defines simple decorations for lines.
    Enumeration Specifies the type of line gap (line spacing) that is applied.
    Enumeration Specifies how the symbol is drawn at the stroke segment connections.
    Enumeration Link chart filter type property data types. Used when specifying link chart filter type as PropertyData.
    Enumeration Link chart filter scope.
    Enumeration Link chart filter stage.
    Enumeration Link chart filter type.
    Enumeration Link chart layout algorithm.
    Enumeration Represents the direction of a Link Chart layout.
    Enumeration Determines how the ideal edge length is computed.
    Enumeration Link chart link dash style.
    Enumeration Link chart link label placement.
    Enumeration Link chart relationship key type.
    Enumeration Link chart node and entity symbolization source.
    Enumeration Location condition types.
    Enumeration Type of locators.
    Enumeration The types of map layers by use in the map or scene.
    Enumeration Maplex abbreviation types.
    Enumeration Maplex anchor point types.
    Enumeration Options to determine how to place a centered point label.
    Enumeration Maplex connection types.
    Enumeration Maplex offset constraint types.
    Enumeration Maplex contour alignment types.
    Enumeration Maplex contour ladder types.
    Enumeration Maplex graticule alignment types.
    Enumeration Maplex key number group horizontal alignment types.
    Enumeration Options that describe how a key numbering group is used.
    Enumeration Identifies the options for reseting the key numbers in a Maplex key numbering group.
    Enumeration Maplex label anchor point.
    Enumeration Maplex rotation types.
    Enumeration Maplex line feature types.
    Enumeration Maplex line placement methods.
    Enumeration Maplex multipart options.
    Enumeration Maplex offset along the line methods.
    Enumeration Maplex point placement methods.
    Enumeration Maplex polygon feature types.
    Enumeration Maplex polygon placement methods.
    Enumeration Maplex quality types.
    Enumeration Options that describe when to remove ambiguous labels.
    Enumeration Maplex rotation alignment types.
    Enumeration Maplex stacking alignment.
    Enumeration Maplex units.
    Enumeration A list of mapped OID field types.
    Enumeration Defines the layout types that meet different map product specifications.
    Enumeration Types of maps.
    Enumeration The map viewing modes.
    Enumeration Marker placement types.
    Enumeration Material modes.
    Enumeration Defines options for 100,000-Square identification area.
    Enumeration Represents the position of the MGRS label in the 100,000m grid square.
    Enumeration Types of mosaic sublayers.
    Enumeration Renderer target.
    Enumeration The source type of the travel mode used by the travel mode context.
    Enumeration A list of north arrows types.
    Enumeration Numeric alignment types.
    Enumeration Specified how features are drawn.
    Enumeration Indicates the way the strokes will display at corners.
    Enumeration Indicates the way strokes will handle complex geometries.
    Enumeration A list of orientation values.
    Enumeration A list of page orientation values.
    Enumeration Types of pansharpening.
    Enumeration Patch shapes.
    Enumeration Options for how markers are placed in a uniform grid or randomly.
    Enumeration Options for how the markers should be clipped at the polygon boundary.
    Enumeration Options for how markers are placed at extremities and control points.
    Enumeration Options for the location on a line where a marker will be placed.
    Enumeration Options for how a single marker will be placed within the polygon.
    Enumeration Options for the amount of randomness to be used for the size and rotation of the markers on the line.
    Enumeration Options for the placement step position.
    Enumeration Point cloud field transform types.
    Enumeration Point cloud return types.
    Enumeration Point cloud shape types.
    Enumeration Point cloud value filter modes.
    Enumeration An enumeration that defines how the background point symbol is scaled to fit the dimensions of the text.
    Enumeration Specifies the direction of the polar progression for the path from the beginning hue to the ending hue.
    Enumeration Target parts of a polygon symbol to which a color can be applied.
    Enumeration Pop-up utility network association types.
    Enumeration Media content (image/video) fit types.
    Enumeration Presentation transition types.
    Enumeration Indicates the types of primitive shapes.
    Enumeration Indicates the types of 3D primitives.
    Enumeration Options for controlling the height of the profile element.
    Enumeration Available styles for profile frames.
    Enumeration Options to specify if profile is displaying straight or curved approach.
    Enumeration Choices of graph line series type.
    Enumeration Choices of what to display in the Y axis.
    Enumeration Options for displaying the base of polygon/polyline obstacles.
    Enumeration Marker display location options.
    Enumeration Types of symbol substitution used to display obstacles.
    Enumeration Options to control how terrain data is displayed.
    Enumeration Represents the sources for automatic project thumbnail generation.
    Enumeration Represents the types of project thumbnail generation.
    Enumeration Controls query behavior with respect to the Provenance Entity Type.
    Enumeration Range relation types.
    Enumeration Raster footprint draw modes.
    Enumeration Raster histogram edit types.
    Enumeration Raster mosaic methods.
    Enumeration Raster mosaic operator type.
    Enumeration Raster resampling types.
    Enumeration Raster stretch statistics types.
    Enumeration Raster stretch types.
    Enumeration A list of rectangle position values.
    Enumeration Restriction status.
    Enumeration Rotation order modes.
    Enumeration Rounding options.
    Enumeration ENC area symbolization type. This is used to specify whether areas should be symbolized with plain or traditional symbols.
    Enumeration ENC Color Schemes.
    Enumeration ENC Depth Display Units.
    Enumeration ENC point symbolization options. This is used to specify whether point features should be symbolized with simplified or paperchart symbols.
    Enumeration A list of scale bar fitting strategies.
    Enumeration Lists the options for the frequency marks appear on the scale bar.
    Enumeration Lists the options for scale bar label positions.
    Enumeration A list of scale bar vertical positions.
    Enumeration Scale display formats.
    Enumeration Scale format types.
    Enumeration Represents the drawing modes of a scene view.
    Enumeration Server types.
    Enumeration Defines the vertical anchor used to render the simple 3D line style in relation to the ground in 3D. This property is ignored for the Strip style which is drawn flat upon the surface, and for the Wall style which always uses a Bottom anchor.
    Enumeration Simple 3D line styles which define how strokes will be rendered in 3D.
    Enumeration Options for how markers are placed at extremities and control points for the Variable Size marker placement.
    Enumeration Size variation methods which define the order in which the change of size in the markers should occur.
    Enumeration Size visual variable axis.
    Enumeration Size visual variable type.
    Enumeration Slider extent types.
    Enumeration Slider interaction modes.
    Enumeration Slider step types.
    Enumeration Snap request types.
    Enumeration Snap tip display parts.
    Enumeration Snap XY tolerance units.
    Enumeration Options to choose sort order type.
    Enumeration Spectral profile display modes.
    Enumeration Spectral Profile horizontal units.
    Enumeration Speed unit types.
    Enumeration Standard deviation multiplier to define min and max data values from the mean for binning levels.
    Enumeration Standard label engine feature weights.
    Enumeration Standard label engine label rotation types.
    Enumeration Standard label engine label weight.
    Enumeration Standard label engine number of labels options.
    Enumeration Standard label engine point placement methods.
    Enumeration Standard label engine polygon placement methods.
    Enumeration Represents the script language used by the statistical data collection.
    Enumeration How to display values of the field in reports.
    Enumeration Stereo model display modes.
    Enumeration Stereo model orientation.
    Enumeration Stereo source types.
    Enumeration List of delimiters for column separation.
    Enumeration A list of ways to wrap data across multiple columns in CIMMapProductBaseStreetIndex.
    Enumeration Stretch types.
    Enumeration Visibility modes for layers inside group layers.
    Enumeration Surface TIN shading modes.
    Enumeration Represents the direction from an edge of the view used to clip a layer.
    Enumeration Symbolization type.
    Enumeration Symbol rotation types.
    Enumeration Symbol shapes.
    Enumeration Symbol substitution types.
    Enumeration Symbol tile unit type.
    Enumeration Symbol unit types.
    Enumeration Table frame fitting strategies.
    Enumeration Defines which table rows to display.
    Enumeration Represents the height of rows in the table view.
    Enumeration Target color surface type.
    Enumeration Units for measuring temperature.
    Enumeration Temporal feature class caching modes.
    Enumeration Temporal feature class purge rules.
    Enumeration Terrain draw cursor types.
    Enumeration The letter case used to draw text.
    Enumeration Text reading directions.
    Enumeration Texture filter types.
    Enumeration 3D Tiles layer types.
    Enumeration Represents the timeline time indicator size.
    Enumeration Timeline lane type.
    Enumeration Timeline layer type.
    Enumeration Represents the timeline symbol style types.
    Enumeration Represents the timeline theme.
    Enumeration Timeline view type.
    Enumeration Time offset direction.
    Enumeration Mode used for snapping the map's current time settings.
    Enumeration Options for how a time span symbol will symbolize boundaries.
    Enumeration Types of trajectory sublayers.
    Enumeration Traversable directions.
    Enumeration Lists the unit type values.
    Enumeration Represents value representations.
    Enumeration The data type of a value.
    Enumeration Vertical alignment types.
    Enumeration Vertical glyph orientation.
    Enumeration Visual variable info types.
    Enumeration Represents voxel alignment.
    Enumeration Voxel interpolation mode.
    Enumeration Represents voxel layer optimization.
    Enumeration Voxel scalar formats.
    Enumeration Voxel value filter modes.
    Enumeration Voxel variable data types.
    Enumeration Voxel variable precision. The lower the precision the smaller the data size of the voxel layer.
    Enumeration Represents voxel visualization.
    Enumeration Waterbody size.
    Enumeration Strength of waves.
    Enumeration Workspace factory types.
