MapViewingMode Enumeration
Test if the view is 3D
//Determine whether the viewing mode is SceneLocal or SceneGlobal
var result = mapView.ViewingMode == MapViewingMode.SceneLocal ||
mapView.ViewingMode == MapViewingMode.SceneGlobal;
// Use the result variable as needed
Check if a Voxel Layer can be created
//Map must be a local scene
bool canCreateVoxel = (MapView.Active.ViewingMode == MapViewingMode.SceneLocal);
if (canCreateVoxel)
//TODO - use the voxel api methods
