ArcGIS.Core.CIM Namespace / MaplexAnchorPointType Enumeration
Example Example
    Maplex anchor point types.
    Syntax
    Members
    MemberDescription
    ErodedCenter Eroded center.
    GeometricCenter Geometric center (of the potentially clipped geometry).
    Perimeter Perimeter.
    UnclippedGeometricCenter Unclipped geometric center.
    Example
    Modify label's Leader Line Anchor point properties - Polygon geometry
      // Note: call within QueuedTask.Run()
        //Check if the label engine is Maplex or standard.
        CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties)
          return;
        //Get the layer's definition
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //If TextSymbol is a call-out the leader line anchor point can be modified
        theLabelClass.MaplexLabelPlacementProperties.PolygonAnchorPointType = MaplexAnchorPointType.Perimeter;
        lyrDefn.LabelClasses = [.. listLabelClasses]; //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.MaplexAnchorPointType
    Requirements
