ArcGIS.Core.CIM Namespace / RasterResamplingType Enumeration
Example Example
    Raster resampling types.
    Syntax
    Members
    MemberDescription
    Average Average.
    BilinearGaussianBlur Bilinear Gaussian blur.
    BilinearGaussianBlurPlus Bilinear Gaussian blur plus.
    BilinearInterpolation Bilinear interpolation.
    BilinearInterpolationPlus Bilinear interpolation plus.
    CubicConvolution Cubic convolution.
    Majority Majority.
    Maximum Maximum.
    Minimum Minimum.
    NearestNeighbor Nearest neighbor.
    VectorAverage Vector average.
    Example
    Update the raster colorizer on a raster layer
        // Get the colorizer from the raster layer.
        //Note: needs to be called on the QueuedTask
        CIMRasterColorizer rasterColorizer = rasterLayer.GetColorizer();
        // Update raster colorizer properties.
        rasterColorizer.Brightness = 10;
        rasterColorizer.Contrast = -5;
        rasterColorizer.ResamplingType = RasterResamplingType.NearestNeighbor;
        // Update the raster layer with the changed colorizer.
        rasterLayer.SetColorizer(rasterColorizer);
    Update the raster colorizer on a mosaic layer
        // Get the image sub-layer from the mosaic layer.
        ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
        // Get the colorizer from the image sub-layer.
        CIMRasterColorizer rasterColorizer = mosaicImageSubLayer.GetColorizer();
        // Update the image sub-layer with the changed colorizer.
        mosaicImageSubLayer.SetColorizer(rasterColorizer);
    Update the raster colorizer on an image service layer
        // Get the colorizer from the image service layer.
        CIMRasterColorizer rasterColorizer = imageServiceLayer.GetColorizer();
        // Update the colorizer properties.
        // Update the image service layer with the changed colorizer.
        imageServiceLayer.SetColorizer(rasterColorizer);
    Get/Set Raster and Imagery Options
    var ro = ApplicationOptions.RasterImageryOptions;
    await QueuedTask.Run(() =>
      var validCategories = ro.GetValidColorRampCategories();
      var validCategory = validCategories.FirstOrDefault();
      var colorRamps = ColorFactory.Instance.GetColorRampNames(validCategory);
      var newColorRampName = colorRamps.FirstOrDefault();
      var stretchedColorRamp = ro.GetStretchedColorRamp();
      var colorRampName = ro.GetStretchedColorRampName();
      ro.SetStretchedColorRampName(null);
      var classifyColorRamp = ro.GetClassifyColorRamp();
      colorRampName = ro.GetClassifyColorRampName();
      ro.SetClassifyColorRampName(newColorRampName);
      var discreteColorRamp = ro.GetDiscreteColorRamp();
      colorRampName = ro.GetDiscreteColorRampName();
      ro.SetDiscreteColorRampName(newColorRampName);
      var uniqueValueColorRamp = ro.GetUniqueValueColorRamp();
      colorRampName = ro.GetUniqueValueColorRampName();
      ro.SetUniqueValueColorRampName(newColorRampName);
      var customRendering = ro.GetEnableCustomRenderingDefaults();
      ro.SetEnableCustomRenderingDefaults(!customRendering);
      var sampleType = ro.GetResampleType();
      ro.SetResampleType(RasterResamplingType.CubicConvolution);
      var stretchType = ro.GetStretchType();
      ro.SetStretchType(RasterStretchType.PercentMinimumMaximum);
      var val = ro.GetNumberOfStandardDeviation();
      ro.SetNumberOfStandardDeviation(3);
      var (clipMin, clipMax) = ro.GetClipPercentage();
      ro.SetClipPercentage(12, 23);
      var red = ro.GetGammaStretchValueRed();
      var green = ro.GetGammaStretchValueGreen();
      var blue = ro.GetGammaStretchValueBlue();
      ro.SetGammaStretchValueRed(2);
      ro.SetGammaStretchValueGreen(20);
      ro.SetGammaStretchValueBlue(60);
      var displayBackground = ro.GetDisplayBackground();
      ro.SetDisplayBackground(!displayBackground);
      var (r, g, b) = ro.GetBackgroundValue();
      ro.SetBackgroundValue(4, 21, 61);
      var backColor = ro.GetBackgroundColor();
      ro.SetBackgroundColor(CIMColor.CreateRGBColor(255, 0, 0));
      var noData = ro.GetNoDataColor();
      ro.SetNoDataColor(CIMColor.CreateRGBColor(0, 255, 0));
      // cache
      var useCache = ro.GetUseImageServiceCache();
      ro.SetUseImageServiceCache(!useCache);
      //dataset
      var opt = ro.GetPyramidOption();
      ro.SetPyramidOption(ArcGIS.Desktop.Core.BuildPyramidOption.NeverBuild);
      var sample = ro.GetPyramidResampleMethod();
      ro.SetPyramidResampleMethod(PyramidResamplingMode.Bilinear);
      var compression = ro.GetPyramidCompressionMethod();
      ro.SetPyramidCompressionMethod(PyramidCompressionType.JPEG_YCbCr);
      var quality = ro.GetPyramidCompressionQuality();
      ro.SetPyramidCompressionQuality(32);
      var stats = ro.GetStatisticsOption();
      ro.SetStatisticsOption(CalculateStatisticOption.AlwaysCalculate);
      var x = ro.GetSkipFactorX();
      ro.SetSkipFactorX(3);
      var y = ro.GetSkipFactorY();
      ro.SetSkipFactorY(23);
      var useWorldFile = ro.GetUseWorldFile();
      ro.SetUseWorldFile(!useWorldFile);
      var createTiledTiff = ro.GetCreateTiledTiff();
      ro.SetCreateTiledTiff(!createTiledTiff);
      var maxUniqueValues = ro.GetMaximumUniqueValues();
      ro.SetMaximumUniqueValues(123456);
      var path = ro.GetProxyFileLocation();
      ro.SetProxyFileLocation("c:\\temp");
      var isExpanded = ro.GetIsMosaicLayerExpanded();
      ro.SetIsMosaicLayerExpanded(!isExpanded);
      var isVisible = ro.GetIsMosaicBoundaryVisible();
      ro.SetIsMosaicBoundaryVisible(!isVisible);
      isVisible = ro.GetIsMosaicFootprintVisible();
      ro.SetIsMosaicFootprintVisible(!isVisible);
      isVisible = ro.GetIsMosaicSeamlinesVisible();
      ro.SetIsMosaicSeamlinesVisible(!isVisible);
      isVisible = ro.GetIsMosaicPreviewVisible();
      ro.SetIsMosaicPreviewVisible(!isVisible);
      var (red_3band, green_3band, blue_3band) = ro.Get3BandColor();
      ro.Set3BandColor(2, 2, 2);
      var (ms_red, ms_green, ms_blue) = ro.GetMSColor();
      ro.SetMSColor(23, 24, 25);
      var enableCustomColorSchemes = ro.GetEnableCustomColorSchemes();
      ro.SetEnableCustomColorSchemes(!enableCustomColorSchemes);
      var useWavelengthInfo = ro.GetUseWavelengthInformation();
      ro.SetUseWavelengthInformation(!useWavelengthInfo);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.RasterResamplingType
    Requirements
