ArcGIS.Core.CIM Namespace / Object3DRenderingMode Enumeration
Example Example
    Specified how features are drawn.
    Syntax
    Members
    MemberDescription
    None Features drawn normally.
    Wireframe Features are drawn as wireframe.
    Example
    Get all the Filters that Contain WireFrame Blocks
      // Note: call within QueuedTask.Run()
        //Note: wire_frame_filters can be null in this example
        var wire_frame_filters = bsl.GetFilters().Where(
          f => f.FilterBlockDefinitions.Any(
            fb => fb.FilterBlockMode == Object3DRenderingMode.Wireframe));
        //substitute Object3DRenderingMode.None to get blocks with a solid mode (default)
        //and...
        //fb.FilterBlockMode == Object3DRenderingMode.Wireframe &&
        //fb.FilterBlockMode == Object3DRenderingMode.None
        //for blocks with both
    Modify BuildingSceneLayer Filter Block
        var filterBlock = new FilterBlockDefinition();
        filterBlock.FilterBlockMode = Object3DRenderingMode.Wireframe;
        var selectedValues = new Dictionary<string, List<string>>();
        //We assume QueryAvailableFieldsAndValues() contains "Walls" and "Doors"
        //For 'Category'
        selectedValues["Category"] = new List<string>() { "Walls", "Doors" };
        filterBlock.SelectedValues = selectedValues;
        //Overwrite
        filter.FilterBlockDefinitions = new List<FilterBlockDefinition>() { filterBlock };
        bsl.UpdateFilter(filter);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.Object3DRenderingMode
    Requirements
