ArcGIS.Core.CIM Namespace / AutoCameraType Enumeration
Example Example
    A list of the options available when using a fixed constraint.
    Syntax
    Members
    MemberDescription
    Center Show the map at the specified center point.
    CenterAndScale Show the map at the specified center point and scale.
    Extent Show the map at a specified extent.
    Scale Show the map at the specified scale.
    Example
    SetAutoCameraFixedExtent
      var autoCamera = mapFrame.GetAutoCamera();
      autoCamera.Source = AutoCameraSource.Fixed;
      autoCamera.AutoCameraType = AutoCameraType.Extent;
      var mf_extent = mapFrame.GetViewExtent();
      var extent = EnvelopeBuilderEx.CreateEnvelope(
        400748.62, 800296.4, 1310669.05, 1424520.74, mapFrame.Map.SpatialReference);
      autoCamera.Extent = extent;
      if (mapFrame.ValidateAutoCamera(autoCamera) &&
        !mapFrame.IsMapSeriesMapFrame())
        mapFrame.SetAutoCamera(autoCamera);
    SetAutoCameraFixedCenter
      //Note: run within the QueuedTask
      autoCamera.AutoCameraType = AutoCameraType.Center;
      var camera = mapFrame.GetMapView(LayoutView.Active).Camera;
      var center = mapFrame.GetViewCenter();
      //var extent = EnvelopeBuilderEx.CreateEnvelope(
      //	400748.62, 800296.4, 1310669.05, 1424520.74, mf.Map.SpatialReference);
      //autoCamera.Extent = extent;
      var camera2 = new CIMViewCamera()
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 21169571,
        X = 855708,
        Y = 1112409,
        Z = double.NaN
      autoCamera.Camera = camera2;
      var states = mapFrame.Map.GetLayersAsFlattenedList().First(l => l.Name == "State_Polygons");
      autoCamera.IntersectLayerPath = states.URI;
    SetAutoCameraFixedCenterAndScale
      autoCamera.AutoCameraType = AutoCameraType.CenterAndScale;
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 21169571,
        X = 1310669.0 + ((400748.5 - 1310669.0) / 2.0),
        Y = 800296.4 + ((1424520.74 - 800296.4) / 2.0),
        Z = double.NaN
      //autoCamera.IntersectLayerPath = states.URI;
    SetAutoCameraFixedScale
      autoCamera.AutoCameraType = AutoCameraType.Scale;
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 20000571,
        Z = double.NaN
    SetAutoCameraLinkedExtent
      autoCamera.Source = AutoCameraSource.MapFrameLink;
      autoCamera.MapFrameLinkName = "mapFrameLink";
    SetAutoCameraLinkedCenter
    SetAutoCameraLinkedCenterAndScale
    SetAutoCameraLinkedScale
    SetAutoCameraLinkedMapSeriesShape
      autoCamera.Source = AutoCameraSource.MapSeriesLink;
      //autoCamera.MapFrameLinkName = mapFrameLink;
    SetAutoCameraLinkedMapSeriesCenter
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.AutoCameraType
    Requirements
