ArcGIS.Core.CIM Namespace / CIMFill Class
Members Example
    CIMFill Class
    Represents a fill which defines how the polygonal geometry is drawn.
    Syntax
    Example
    Diagonal cross hatch fill
    /// <summary>
    /// Create a polygon symbol with a diagonal cross hatch fill. <br/>
    /// ![PolygonSymbolDiagonalCrossHatch](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-diagonal-crosshatch.png)
    /// </summary>
      var trans = 50.0;//semi transparent
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(0, 0, 0, trans), 2.0, SimpleLineStyle.Solid);
      //Stroke for the fill
      var solid = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(255, 0, 0, trans), 1.0, SimpleLineStyle.Solid);
      //Mimic cross hatch
      CIMFill[] diagonalCross =
                  new CIMHatchFill() {
                      Enable = true,
                      Rotation = 45.0,
                      Separation = 5.0,
                      LineSymbol = new CIMLineSymbol() { SymbolLayers = new CIMSymbolLayer[1] { solid } }
                      Enable = true,
                      Rotation = -45.0,
                      Separation = 5.0,
      List<CIMSymbolLayer> symbolLayers =
          outline, .. diagonalCross
      //This is the polygon symbol with a diagonal cross hatch fill
      CIMPolygonSymbol diagonalCrossHatchFillSymbol = new()
        SymbolLayers = [.. symbolLayers]
      //To apply the symbol to a polygon feature layer
      //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = diagonalCrossHatchFillSymbol.MakeSymbolReference();
      //theLayer.SetRenderer(renderer);
    Gradient color fill using CIMGradientFill
    /// <summary>
    /// Create a polygon symbol with a gradient color fill. <br/>
    /// ![PolygonSymbolGradientColor](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-gradient-color.png)
    /// 1. Create a solid colored stroke with 50% transparency
    /// 1. Create a fill using gradient colors red through green
    /// 1. Apply both the stroke and fill as a symbol layer array to the new PolygonSymbol
    /// </summary>
      //Note: Run withing QueuedTask
      //Mimic cross hatch
      CIMFill solidColorHatch =
             new CIMGradientFill()
               ColorRamp = ColorFactory.Instance.ConstructColorRamp(ColorRampAlgorithm.LinearContinuous,
                                    ColorFactory.Instance.RedRGB, ColorFactory.Instance.GreenRGB)
      List<CIMSymbolLayer> symbolLayers = new List<CIMSymbolLayer>
                  outline,
                  solidColorHatch
      CIMPolygonSymbol gradientColorFillPolygon = new CIMPolygonSymbol() { SymbolLayers = symbolLayers.ToArray() };
      //renderer.Symbol = gradientColorFillPolygon.MakeSymbolReference();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMSymbolLayer
             ArcGIS.Core.CIM.CIMFill
                ArcGIS.Core.CIM.CIMGradientFill
                ArcGIS.Core.CIM.CIMHatchFill
                ArcGIS.Core.CIM.CIMPictureFill
                ArcGIS.Core.CIM.CIMSolidFill
                ArcGIS.Core.CIM.CIMWaterFill
    Requirements
