ArcGIS.Core.CIM Namespace / CIMHatchFill Class
Members Example
    CIMHatchFill Class
    Represents a hatch fill which fills polygonal geometry with a uniform series of parallel line symbols.
    Object Model
    CIMHatchFill ClassCIMHatchFill ClassCIMHatchFill ClassCIMLineSymbol Class
    Syntax
    Example
    Diagonal cross hatch fill
    /// <summary>
    /// Create a polygon symbol with a diagonal cross hatch fill. <br/>
    /// ![PolygonSymbolDiagonalCrossHatch](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-diagonal-crosshatch.png)
    /// </summary>
      var trans = 50.0;//semi transparent
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(0, 0, 0, trans), 2.0, SimpleLineStyle.Solid);
      //Stroke for the fill
      var solid = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(255, 0, 0, trans), 1.0, SimpleLineStyle.Solid);
      //Mimic cross hatch
      CIMFill[] diagonalCross =
                  new CIMHatchFill() {
                      Enable = true,
                      Rotation = 45.0,
                      Separation = 5.0,
                      LineSymbol = new CIMLineSymbol() { SymbolLayers = new CIMSymbolLayer[1] { solid } }
                      Enable = true,
                      Rotation = -45.0,
                      Separation = 5.0,
      List<CIMSymbolLayer> symbolLayers =
          outline, .. diagonalCross
      //This is the polygon symbol with a diagonal cross hatch fill
      CIMPolygonSymbol diagonalCrossHatchFillSymbol = new()
        SymbolLayers = [.. symbolLayers]
      //To apply the symbol to a polygon feature layer
      //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = diagonalCrossHatchFillSymbol.MakeSymbolReference();
      //theLayer.SetRenderer(renderer);
    Dash dot fill
    /// <summary>
    /// Create a polygon symbol with a dash dot fill. <br/>
    /// ![PolygonSymbolDashDot](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-dash-dot.png)
    /// </summary>
      //Note: Run withing QueuedTask
      var dashDot = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 1.0, SimpleLineStyle.DashDotDot);
      //Mimic cross hatch
      CIMFill[] solidColorHatch =
               new CIMHatchFill()
                  Enable = true,
                  Rotation = 0.0,
                  Separation = 2.5,
                  LineSymbol = new CIMLineSymbol(){SymbolLayers = new CIMSymbolLayer[1] {dashDot } }
               new CIMSolidFill()
                  Enable = true,
                  Color = ColorFactory.Instance.CreateRGBColor(255, 255, 0)
      List<CIMSymbolLayer> symbolLayers = [outline, .. solidColorHatch];
      //This is the polygon symbol with a dash dot fill
      CIMPolygonSymbol dashDotFillPolygon = new CIMPolygonSymbol() { SymbolLayers = symbolLayers.ToArray() };
      //renderer.Symbol = dashDotFillPolygon.MakeSymbolReference();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMSymbolLayer
             ArcGIS.Core.CIM.CIMFill
                ArcGIS.Core.CIM.CIMHatchFill
    Requirements
