Public Class CIMGradientFill Inherits CIMFill Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMGradientFill : CIMFill, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
/// <summary> /// Create a polygon symbol with a gradient color fill. <br/> ///  /// 1. Create a solid colored stroke with 50% transparency /// 1. Create a fill using gradient colors red through green /// 1. Apply both the stroke and fill as a symbol layer array to the new PolygonSymbol /// </summary> { //Note: Run withing QueuedTask var trans = 50.0;//semi transparent CIMStroke outline = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(0, 0, 0, trans), 2.0, SimpleLineStyle.Solid); //Mimic cross hatch CIMFill solidColorHatch = new CIMGradientFill() { ColorRamp = ColorFactory.Instance.ConstructColorRamp(ColorRampAlgorithm.LinearContinuous, ColorFactory.Instance.RedRGB, ColorFactory.Instance.GreenRGB) }; List<CIMSymbolLayer> symbolLayers = new List<CIMSymbolLayer> { outline, solidColorHatch }; CIMPolygonSymbol gradientColorFillPolygon = new CIMPolygonSymbol() { SymbolLayers = symbolLayers.ToArray() }; //To apply the symbol to a polygon feature layer //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer; //renderer.Symbol = gradientColorFillPolygon.MakeSymbolReference(); //theLayer.SetRenderer(renderer); }
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMSymbolLayer
ArcGIS.Core.CIM.CIMFill
ArcGIS.Core.CIM.CIMGradientFill
