Public Class CIMColorModulationInfo Inherits CIMObject Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMColorModulationInfo : CIMObject, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
// Note: call within QueuedTask.Run()
var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
PointCloudRendererType.StretchRenderer);
var stretchDef = new PointCloudRendererDefinition(
//Will be either ELEVATION or INTENSITY
Field = fields[0]
//Create the CIM Renderer
var stretchRenderer = pointCloudSceneLayer.CreateRenderer(stretchDef)
as CIMPointCloudStretchRenderer;
//Apply a color ramp
var style = Project.Current.GetItems<StyleProjectItem>()
.First(s => s.Name == "ArcGIS Colors");
var colorRamp = style.SearchColorRamps("").First();
stretchRenderer.ColorRamp = colorRamp.ColorRamp;
//Apply modulation
stretchRenderer.ColorModulation = new CIMColorModulationInfo()
MinValue = 0,
MaxValue = 100
//apply the renderer
pointCloudSceneLayer.SetRenderer(stretchRenderer);
var def = pointCloudSceneLayer.GetDefinition() as CIMPointCloudLayer;
//Get the ColorModulation off the renderer
var modulation = def.Renderer.ColorModulation;
if (modulation == null)
modulation = new CIMColorModulationInfo();
//Set the minimum and maximum intensity as needed
modulation.MinValue = 0;
modulation.MaxValue = 100.0;
//apply back
def.Renderer.ColorModulation = modulation;
//Commit changes back to the CIM
pointCloudSceneLayer.SetDefinition(def);
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMColorModulationInfo
