Public Class CIMKnowledgeGraphCentralityConfiguration Inherits CIMObject Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMKnowledgeGraphCentralityConfiguration : CIMObject, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
//using ArcGIS.Core.Data.Knowledge.Extensions;
await QueuedTask.Run(() =>
//using(var kg = ....) {
//take default settings...
//undirected relationship interpretation
//use default relationship importance = 0
//use default relationship cost = 0
//use default Multiedge factor = 0
//no normalization
var kg_config = new CIMKnowledgeGraphCentralityConfiguration();
//include all entities from the kg in the subgraph
//(no filters)
var kg_subgraph = new CIMKnowledgeGraphSubGraph();
//include all centrality measures
CentralityMeasure[] measures = [
CentralityMeasure.Degree,
CentralityMeasure.InDegree,
CentralityMeasure.OutDegree,
CentralityMeasure.Coreness,//Coreness only wks w/ undirected relates
CentralityMeasure.Betweenness,
CentralityMeasure.Closeness,
CentralityMeasure.Harmonic,
CentralityMeasure.Eigenvector,
CentralityMeasure.PageRank
//compute centrality
var kg_centrality_results = kg.ComputeCentrality(
kg_config, kg_subgraph, measures);
//TODO - process results
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMKnowledgeGraphCentralityConfiguration
