ArcGIS.Core.CIM Namespace / TableRowHeightType Enumeration
Example Example
    Represents the height of rows in the table view.
    Syntax
    Members
    MemberDescription
    Double The row will display two lines of text.
    None No row height.
    Single The row will display one line of text.
    Triple The row will display three lines of text.
    Example
    Get/Set Table Options
      var options = ApplicationOptions.TableOptions;
      var hideAddNewRow = options.HideAddNewRow;
      options.HideAddNewRow = !hideAddNewRow;
      var overrides = options.HonorSelectionColorOverrides;
      options.HonorSelectionColorOverrides = !overrides;
      var activateMapView = options.ActivateMapViewAfterOperations;
      options.ActivateMapViewAfterOperations = !activateMapView;
      var defaultFontTName = options.DefaultFontName;
      var fontName = options.FontName;
      if (options.IsValidFontName("Arial"))
        options.FontName = "Arial";
      var defaultFontSize = options.DefaultFontSize;
      var fontSize = options.FontSize;
      if (options.IsValidFontSize(10))
        options.FontSize = 10;
      var heightType = options.ColumnHeaderHeightType;
      options.ColumnHeaderHeightType = TableRowHeightType.Double;
      var rowHeightType = options.RowHeightType;
      options.RowHeightType = TableRowHeightType.Single;
      var defaultColor = options.DefaultHighlightColor;
      var color = options.HighlightColor;
      // Note: Needs QueuedTask to run
      options.SetHighlightColor(ColorFactory.Instance.CreateRGBColor(0, 0, 255));
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.TableRowHeightType
    Requirements
    ArcGIS Pro version: 3.2 or higher.
