VoxelVariableDataType Enumeration
Get the Variable Renderer
var variable = voxelLayer.GetVariableProfiles().First();
var renderer = variable.Renderer;
if (variable.DataType == VoxelVariableDataType.Continuous)
//Renderer will be stretch
var stretchRenderer = renderer as CIMVoxelStretchRenderer;
//access the renderer
else //VoxelVariableDataType.Discrete
//Renderer will be unique value
var uvr = renderer as CIMVoxelUniqueValueRenderer;
Access Stats and Color Range for a Stretch Renderer
//Get the variable profile on which to access the data
var variable = voxelLayer.SelectedVariableProfile;
//or use ...voxelLayer.GetVariableProfiles()
//Data range
var min = variable.Statistics.MinimumValue;
var max = variable.Statistics.MaximumValue;
//Color range (Continuous only)
double color_min, color_max;
var renderer = variable.Renderer as CIMVoxelStretchRenderer;
color_min = renderer.ColorRangeMin;
color_max = renderer.ColorRangeMax;
System.Object
System.ValueType
System.Enum
ArcGIS.Core.CIM.VoxelVariableDataType
