ArcGIS.Core.CIM Namespace / CIMColorClassBreak Class
Members Example
    Represents a color class break.
    Object Model
    CIMColorClassBreak ClassCIMColorClassBreak ClassCIMColor ClassCIMColorClassBreak Class
    Syntax
    Example
    Create and Set a ClassBreaks Renderer
      // Note: call within QueuedTask.Run()
        var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
                           PointCloudRendererType.ClassBreaksRenderer);
        var classBreakDef = new PointCloudRendererDefinition(
          //ELEVATION or INTENSITY
          Field = fields[0]
        //create the renderer
        var cbr = pointCloudSceneLayer.CreateRenderer(classBreakDef)
                                  as CIMPointCloudClassBreaksRenderer;
        //Set up a color scheme to use
        var style = Project.Current.GetItems<StyleProjectItem>()
                                   .First(s => s.Name == "ArcGIS Colors");
        var rampStyle = style.LookupItem(
          StyleItemType.ColorRamp, "Spectrum By Wavelength-Full Bright_Multi-hue_2")
        as ColorRampStyleItem;
        var colorScheme = rampStyle.ColorRamp;
        //Set up 6 manual class breaks
        var breaks = 6;
        var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
                                                    colorScheme, breaks);
        var classBreaks = new List<CIMColorClassBreak>();
        var min = cbr.Breaks[0].UpperBound;
        var max = cbr.Breaks[cbr.Breaks.Count() - 1].UpperBound;
        var step = (max - min) / (double)breaks;
        //add in the class breaks
        double upper = min;
        for (int b = 1; b <= breaks; b++)
          double lower = upper;
          upper = b == breaks ? max : min + (b * step);
          var cb = new CIMColorClassBreak()
            UpperBound = upper,
            Label = string.Format("{0:#0.0#} - {1:#0.0#}", lower, upper),
            Color = colors[b - 1]
          classBreaks.Add(cb);
        cbr.Breaks = classBreaks.ToArray();
        pointCloudSceneLayer.SetRenderer(cbr);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMColorClassBreak
    Requirements
