ArcGIS.Core.CIM Namespace / CIMGraticule Class
Members Example
    CIMGraticule Class
    Represents a graticule for a map frame.
    Object Model
    CIMGraticule ClassCIMGraticule ClassMapPoint ClassCIMGraticule ClassSpatialReference ClassCIMSymbolReference Class
    Syntax
    Example
    Apply a style to Grid and Graticules
      //Note: Must be on QueuedTask.Run
      //Get the Style project items in the project
      var styleProjectItems = Project.Current?.GetItems<StyleProjectItem>();
      //Get the ArcGIS 2D Style Project Item
      var styleProjectItem =
      styleProjectItems.OfType<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
      if (styleProjectItem == null) return;
      //Get the grid style item you need
      var gridStyleItem =
      styleProjectItem.SearchSymbols(StyleItemType.Grid, "Blue Vertical Label Graticule").FirstOrDefault();
      if (gridStyleItem == null) return;
      var symbolItemName = gridStyleItem.Name;
      var girdGraticuleObject = gridStyleItem.GetObject() as CIMMapGrid;
      var cmf = mapFrame.GetDefinition() as CIMMapFrame;
      //note, if page units are _not_ inches then grid's gridline
      //lengths and offsets would need to be converted to the page units
      var mapGrids = new List<CIMMapGrid>();
      if (cmf.Grids != null)
        mapGrids.AddRange(cmf.Grids);
      switch (girdGraticuleObject)
        case CIMGraticule:
          var gridGraticule = girdGraticuleObject as CIMGraticule;
          gridGraticule.Name = symbolItemName;
          gridGraticule.SetGeographicCoordinateSystem(mapFrame.Map.SpatialReference);
          //assign grid to the frame
          mapGrids.Add(gridGraticule);
          break;
        case CIMMeasuredGrid:
          var gridMeasure = girdGraticuleObject as CIMMeasuredGrid;
          gridMeasure.Name = symbolItemName;
          gridMeasure.SetProjectedCoordinateSystem(mapFrame.Map.SpatialReference);
          mapGrids.Add(gridMeasure);
          break;
        case CIMReferenceGrid:
          var gridReference = girdGraticuleObject as CIMReferenceGrid;
          gridReference.Name = symbolItemName;
          mapGrids.Add(gridReference);
          break;
      cmf.Grids = mapGrids.ToArray();
      mapFrame.SetDefinition(cmf);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMMapGrid
             ArcGIS.Core.CIM.CIMGraticule
    Requirements
