public class CIMTextGraphic : CIMTextGraphicBase, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
Public Class CIMTextGraphic Inherits CIMTextGraphicBase Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
var oid = 1; //ObjectID of the annotation feature to modify
await QueuedTask.Run(() =>
//Don't use 'Shape'....Shape is the bounding box of the annotation text. This is NOT what you want...
//var insp = new Inspector();
//insp.Load(annotationLayer, oid);
//var shape = insp["SHAPE"] as Polygon;
//...wrong shape...
//Instead, we must get the TextGraphic from the anno feature.
//The TextGraphic shape will be the anno baseline...
QueryFilter qf = new QueryFilter()
WhereClause = "OBJECTID = 1"
//annotationLayer is ~your~ Annotation layer
using var rowCursor = annotationLayer.Search(qf);
if (rowCursor.MoveNext())
using (var annoFeature = rowCursor.Current as
ArcGIS.Core.Data.Mapping.AnnotationFeature)
var graphic = annoFeature.GetGraphic();
var textGraphic = graphic as CIMTextGraphic;
var textLine = textGraphic.Shape as Polyline;
// rotate the shape 90 degrees
var origin = GeometryEngine.Instance.Centroid(textLine);
Geometry rotatedPolyline = GeometryEngine.Instance.Rotate(textLine, origin, System.Math.PI / 2);
//Move the line 5 "units" in the x and y direction
//GeometryEngine.Instance.Move(textLine, 5, 5);
EditOperation op = new EditOperation();
op.Name = "Change annotation angle";
op.Modify(annotationLayer, oid, rotatedPolyline);
op.Execute();
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMGraphic
ArcGIS.Core.CIM.CIMTextGraphicBase
