ArcGIS.Core.CIM Namespace / CIMPolygonGraphic Class
Members Example
    Represents a polygon graphic.
    Object Model
    CIMPolygonGraphic ClassCIMPolygonGraphic ClassCIMPolygonGraphic ClassPolygon ClassCIMSymbolReference Class
    Syntax
    Example
    Polygon Graphic Element using CIMGraphic
      // Note: must be called on the QueuedTask
        //On the QueuedTask
        //Place a polygon symbol using the mapview extent geometry
        var extent = MapView.Active.Extent;
        //Contract the extent
        var polygonEnv = extent.Expand(-100000, -90000, false);
        //create a polygon using the envelope
        var polygon = PolygonBuilderEx.CreatePolygon(polygonEnv);
        //specify a symbol
        var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                              ColorFactory.Instance.GreenRGB);
        //create a CIMGraphic
        var graphic = new CIMPolygonGraphic()
          Symbol = poly_symbol.MakeSymbolReference(),
          Polygon = polygon,
        graphicsLayer.AddElement(graphic);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMGraphic
             ArcGIS.Core.CIM.CIMShapeGraphic
                ArcGIS.Core.CIM.CIMPolygonGraphic
    Requirements
