ArcGIS.Core.CIM Namespace / CIMUniqueValueRenderer Class
Members Example
    Represents a unique value renderer.
    Object Model
    CIMUniqueValueRenderer ClassCIMUniqueValueRendererAuthoringInfo ClassCIMUniqueValueRenderer ClassCIMColorRamp ClassCIMSymbolReference ClassCIMLegendPatch ClassCIMUniqueValueRenderer ClassCIMExpressionInfo Class
    Syntax
    Example
    Set unique value renderer to the selected feature layer of the active map
      await QueuedTask.Run(() =>
      //field to be used to retrieve unique values
      var fields = new List<string> { "Type" };
      //constructing a point symbol as a template symbol
      CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
          ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Pushpin);
      CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
      //constructing renderer definition for unique value renderer
      UniqueValueRendererDefinition uniqueValueRendererDef =
    new UniqueValueRendererDefinition(fields, symbolPointTemplate);
      //creating a unique value renderer
      CIMUniqueValueRenderer uniqueValueRenderer = featureLayer.CreateRenderer(uniqueValueRendererDef) as CIMUniqueValueRenderer;
      //setting the renderer to the feature layer
      featureLayer.SetRenderer(uniqueValueRenderer);
    Create a UniqueValueRenderer to specify symbols to values
      //The goal is to construct the CIMUniqueValueRenderer which will be applied to the feature layer.
      // To do this, the following are the objects we need to set the renderer up with the fields and symbols.
      // As a reference, this is the USCities dataset. Snippet will create a unique value renderer that applies
      // specific symbols to all the cities in California and Alabama.  The rest of the cities will use a default symbol.
      // First create a "CIMUniqueValueClass" for the cities in Alabama.
      List<CIMUniqueValue> listUniqueValuesAlabama = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "Alabama" } } };
      CIMUniqueValueClass alabamaUniqueValueClass = new CIMUniqueValueClass
        Editable = true,
        Label = "Alabama",
        Patch = PatchShape.Default,
        Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
        Visible = true,
        Values = listUniqueValuesAlabama.ToArray()
      // Create a "CIMUniqueValueClass" for the cities in California.
      List<CIMUniqueValue> listUniqueValuescalifornia = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "California" } } };
      CIMUniqueValueClass californiaUniqueValueClass = new CIMUniqueValueClass
        Editable = true,
        Label = "California",
        Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
        Visible = true,
        Values = listUniqueValuescalifornia.ToArray()
      //Create a list of the above two CIMUniqueValueClasses
      List<CIMUniqueValueClass> listUniqueValueClasses = new List<CIMUniqueValueClass>
                    alabamaUniqueValueClass, californiaUniqueValueClass
      //Create a list of CIMUniqueValueGroup
      CIMUniqueValueGroup uvg = new CIMUniqueValueGroup
        Classes = listUniqueValueClasses.ToArray(),
      List<CIMUniqueValueGroup> listUniqueValueGroups = new List<CIMUniqueValueGroup> { uvg };
      //Create the CIMUniqueValueRenderer
      CIMUniqueValueRenderer uvr = new CIMUniqueValueRenderer
        UseDefaultSymbol = true,
        DefaultLabel = "all other values",
        DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
        Groups = listUniqueValueGroups.ToArray(),
        Fields = new string[] { "STATE_NAME" }
      //Set the feature layer's renderer.
      featureLayer.SetRenderer(uvr);
    Setting a unique value renderer for latest observations
        var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
        var uri = new Uri(url, UriKind.Absolute);
        var createParams = new FeatureLayerCreationParams(uri)
          IsVisible = false
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(
                            createParams, map);
        //Define the unique values by hand
        var uvr = new CIMUniqueValueRenderer()
          Fields = new string[] { "ACTYPE" },
          DefaultLabel = "Others",
                      CIMColor.CreateRGBColor(185, 185, 185), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        var classes = new List<CIMUniqueValueClass>
          //add in classes - one for ACTYPE of 727, one for DC 9
          new CIMUniqueValueClass()
            Values = new CIMUniqueValue[] {
                    new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
            Visible = true,
            Label = "Boeing 727",
                      ColorFactory.Instance.RedRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
                    new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
            Visible = true,
            Label = "DC 9",
                      ColorFactory.Instance.GreenRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //add the classes to a group
        var groups = new List<CIMUniqueValueGroup>()
        new CIMUniqueValueGroup() {
           Classes = classes.ToArray()
        //add the groups to the renderer
        uvr.Groups = groups.ToArray();
        //Apply the renderer (for current observations)
        streamLayer.SetRenderer(uvr);
        streamLayer.SetVisibility(true);//turn on the layer
    Setting a unique value renderer for latest observations 2
        //Define the classes by hand to avoid using CreateRenderer(...)
        CIMUniqueValueClass uvcB727 = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
          Visible = true,
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        CIMUniqueValueClass uvcD9 = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
          Visible = true,
          Label = "DC 9",
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(0, 255, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //Assign the classes to a group
        CIMUniqueValueGroup uvGrp = new CIMUniqueValueGroup()
          Classes = new CIMUniqueValueClass[] { uvcB727, uvcD9 }
        //assign the group to the renderer
        var UVrndr = new CIMUniqueValueRenderer()
          Groups = new CIMUniqueValueGroup[] { uvGrp },
        //set the renderer. Depending on the current events received, the
        //layer may or may not have events for each of the specified
        //unique value classes
        streamLayer.SetRenderer(UVrndr);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMRenderer
             ArcGIS.Core.CIM.CIMUniqueValueRenderer
    Requirements
