ArcGIS.Core.CIM Namespace / CIMUniqueValueRenderer Class
Properties Methods Events
    CIMUniqueValueRenderer Class Members
    The following tables list the members exposed by CIMUniqueValueRenderer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the property that controls how the color ramp is applied to polygon symbols.
    Public Property Gets or sets the color ramp.
    Public Property Gets or sets the default description.
    Public Property Gets or sets the default label.
    Public Property Gets or sets the default symbol.
    Public Property Gets or sets the custom patch for the default symbol.
    Public Property Gets or sets the patch shape for the default symbol.
    Public Property Gets or sets the fields used by this renderer.
    Public Property Gets or sets the unique value groups.
    Public Property Gets or sets a value indicating whether or not the default symbol is visible.
    Public Property Gets or sets the maximum number of records to sample.
    Public Property Gets or sets a value indicating whether the class visibility is shown in the contents pane.
    Public Property Gets or sets the style item name for the color ramp.
    Public Property Gets or sets a value indicating whether or not to use the default symbol.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a string. When both Fields and ValueExpressionInfo are present ValueExpressionInfo is used.
    Public Property Gets or sets the visual variables.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMUniqueValueRenderer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMUniqueValueRenderer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMUniqueValueRenderer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
