ArcGIS.Core.CIM Namespace / CIMUniqueValueRenderer Class / ValueExpressionInfo Property
Example
    ValueExpressionInfo Property (CIMUniqueValueRenderer)
    Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a string. When both Fields and ValueExpressionInfo are present ValueExpressionInfo is used.
    Syntax
    public CIMExpressionInfo ValueExpressionInfo {get; set;}
    Public Property ValueExpressionInfo As CIMExpressionInfo
    Example
    Modify renderer using Arcade
      await QueuedTask.Run(() =>
        // GetRenderer from Layer (assumes it is a unique value renderer)
        if (featureLayer.GetRenderer() is not CIMUniqueValueRenderer uvRenderer)
          // not a unique value renderer, leave
          return;
        //layer has STATE_NAME field if using the community sample Data\Admin\AdminSample.aprx
        string expression = "if ($view.scale > 21000000) { return $feature.STATE_NAME } else { return 'All' }";
        CIMExpressionInfo updatedExpressionInfo = new()
          Expression = expression,
          Title = "Custom" // can be any string used for UI purpose.
        //set the renderer's expression
        uvRenderer.ValueExpressionInfo = updatedExpressionInfo;
        //SetRenderer on Layer
        featureLayer.SetRenderer(uvRenderer);
    Requirements
