ArcGIS.Core.CIM Namespace / CIMUniqueValueRenderer Class / DefaultLabel Property
Example
    DefaultLabel Property (CIMUniqueValueRenderer)
    Gets or sets the default label.
    Syntax
    Public Property DefaultLabel As String
    public string DefaultLabel {get; set;}
    Example
    Create a UniqueValueRenderer to specify symbols to values
            //The goal is to construct the CIMUniqueValueRenderer which will be applied to the feature layer.
            // To do this, the following are the objects we need to set the renderer up with the fields and symbols.
            // As a reference, this is the USCities dataset. Snippet will create a unique value renderer that applies
            // specific symbols to all the cities in California and Alabama.  The rest of the cities will use a default symbol.
            // First create a "CIMUniqueValueClass" for the cities in Alabama.
            List<CIMUniqueValue> listUniqueValuesAlabama = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "Alabama" } } };
            CIMUniqueValueClass alabamaUniqueValueClass = new CIMUniqueValueClass
                Editable = true,
                Label = "Alabama",
                Patch = PatchShape.Default,
                Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
                Visible = true,
                Values = listUniqueValuesAlabama.ToArray()
            // Create a "CIMUniqueValueClass" for the cities in California.
            List<CIMUniqueValue> listUniqueValuescalifornia = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "California" } } };
            CIMUniqueValueClass californiaUniqueValueClass = new CIMUniqueValueClass
                Editable = true,
                Label = "California",
                Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
                Visible = true,
                Values = listUniqueValuescalifornia.ToArray()
            //Create a list of the above two CIMUniqueValueClasses
            List<CIMUniqueValueClass> listUniqueValueClasses = new List<CIMUniqueValueClass>
                  alabamaUniqueValueClass, californiaUniqueValueClass
            //Create a list of CIMUniqueValueGroup
            CIMUniqueValueGroup uvg = new CIMUniqueValueGroup
                Classes = listUniqueValueClasses.ToArray(),
            List<CIMUniqueValueGroup> listUniqueValueGroups = new List<CIMUniqueValueGroup> { uvg };
            //Create the CIMUniqueValueRenderer
            CIMUniqueValueRenderer uvr = new CIMUniqueValueRenderer
                UseDefaultSymbol = true,
                DefaultLabel = "all other values",
                DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
                Groups = listUniqueValueGroups.ToArray(),
                Fields = new string[] { "STATE_NAME" }
            //Set the feature layer's renderer.
            //Note: Run within a QueuedTask
            featureLayer.SetRenderer(uvr);
    Setting a unique value renderer for latest observations
      // Note: call within QueuedTask.Run()
        var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
        var uri = new Uri(url, UriKind.Absolute);
        var createParams = new FeatureLayerCreationParams(uri)
          IsVisible = false
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(
                            createParams, map);
        //Define the unique values by hand
        var uvr = new CIMUniqueValueRenderer()
          Fields = new string[] { "ACTYPE" },
          DefaultLabel = "Others",
                      CIMColor.CreateRGBColor(185, 185, 185), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        var classes = new List<CIMUniqueValueClass>
          //add in classes - one for ACTYPE of 727, one for DC 9
          new CIMUniqueValueClass()
            Values = new CIMUniqueValue[] {
                    new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
            Visible = true,
            Label = "Boeing 727",
                      ColorFactory.Instance.RedRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
                    new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
            Visible = true,
            Label = "DC 9",
                      ColorFactory.Instance.GreenRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //add the classes to a group
        var groups = new List<CIMUniqueValueGroup>()
        new CIMUniqueValueGroup() {
           Classes = classes.ToArray()
        //add the groups to the renderer
        uvr.Groups = groups.ToArray();
        //Apply the renderer (for current observations)
        streamLayer.SetRenderer(uvr);
        streamLayer.SetVisibility(true);//turn on the layer
    Setting a unique value renderer for latest observations 2
        //Define the classes by hand to avoid using CreateRenderer(...)
        CIMUniqueValueClass uvcB727 = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
          Visible = true,
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        CIMUniqueValueClass uvcD9 = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
          Visible = true,
          Label = "DC 9",
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(0, 255, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //Assign the classes to a group
        CIMUniqueValueGroup uvGrp = new CIMUniqueValueGroup()
          Classes = new CIMUniqueValueClass[] { uvcB727, uvcD9 }
        //assign the group to the renderer
        var UVrndr = new CIMUniqueValueRenderer()
          Groups = new CIMUniqueValueGroup[] { uvGrp },
        //set the renderer. Depending on the current events received, the
        //layer may or may not have events for each of the specified
        //unique value classes
        streamLayer.SetRenderer(UVrndr);
    Requirements
