ArcGIS.Core.CIM Namespace / MaplexLabelRotationType Enumeration
Example Example
    Maplex rotation types.
    Syntax
    Members
    MemberDescription
    Arithmetic Arithmetic rotation.
    AV3 ArcView 3 rotation.
    Geographic Geographic rotation.
    Radians Rotation in radians.
    Example
    Modify label Rotation - Point geometry
      // Note: call within QueuedTask.Run()
        //Check if the label engine is Maplex or standard.
        CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties)
          return;
        //Get the layer's definition
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //Modify label Rotation
        CIMMaplexRotationProperties rotationProperties = new CIMMaplexRotationProperties
          Enable = true, //Enable rotation
          RotationField = "ELEVATION", //Field that is used to define rotation angle
          AdditionalAngle = 15, //Additional rotation
          RotationType = MaplexLabelRotationType.Arithmetic,
          AlignmentType = MaplexRotationAlignmentType.Perpendicular,
          AlignLabelToAngle = true
        theLabelClass.MaplexLabelPlacementProperties.RotationProperties = rotationProperties;
        lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.MaplexLabelRotationType
    Requirements
