// Note: call within QueuedTask.Run()
//Get the layer's definition
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//Modify label Placement
//Check if the label engine is Maplex or standard.
CIMGeneralPlacementProperties labelEngine =
MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
if (labelEngine is CIMStandardGeneralPlacementProperties)
//Current labeling engine is Standard labeling engine
var lineLablePosition = new CIMStandardLineLabelPosition
Perpendicular = true,
Parallel = false,
ProduceCurvedLabels = false,
Horizontal = false,
OnTop = true
theLabelClass.StandardLabelPlacementProperties.LineLabelPosition =
lineLablePosition;
else //Current labeling engine is Maplex labeling engine
theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod =
MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
theLabelClass.MaplexLabelPlacementProperties.LineFeatureType =
MaplexLineFeatureType.General;
//theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod = MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
featureLayer.SetDefinition(lyrDefn); //set the layer's definition
