ArcGIS.Core.CIM Namespace / CIMProportionalRenderer Class
Members Example
    Represents a proportional renderer.
    Object Model
    CIMProportionalRenderer ClassCIMProportionalRendererAuthoringInfo ClassCIMSymbolReference ClassCIMProportionalRenderer ClassCIMSymbolReference ClassCIMLegendPatch ClassCIMSymbolReference ClassCIMLegendPatch ClassCIMProportionalRenderer ClassCIMSymbolReference ClassCIMUnitSymbolization ClassCIMExpressionInfo Class
    Syntax
    Example
    Create a Proportion Renderer with max and min symbol size capped
        string colorBrewerSchemesName = "ArcGIS Colors";
        //Get the style project item that contains the color ramps
        //Refer to the Initialize region for an example of how to get a style item
        //Note: Run within a QueuedTask
        //Creating a point symbol to be used as a template symbol for the proportional renderer
        CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
        CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
        //minimum symbol size is capped to 4 point while the maximum symbol size is set to 50 point
        //Creating a proportional renderer definition that uses the "Population" field
        ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", symbolPointTemplate, 4, 50, true)
            //setting upper and lower size stops to stop symbols growing or shrinking beyond those thresholds
            UpperSizeStop = 5000000,  //features with values >= 5,000,000 will be drawn with maximum symbol size
            LowerSizeStop = 50000    //features with values <= 50,000 will be drawn with minimum symbol size
        // Create a proportional renderer using the definition
        CIMProportionalRenderer propRndr = featureLayer.CreateRenderer(prDef) as CIMProportionalRenderer;
        // Set the renderer to the feature layer
        featureLayer.SetRenderer(propRndr);
    Create a True Proportion Renderer
        //Defining proportional renderer where size of symbol will be same as its value in field used in the renderer.
        ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", esriUnits.esriMeters, symbolPointTemplate, SymbolShapes.Square, ValueRepresentations.Radius);
        //Create a Proportional renderer using the definition
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMRenderer
             ArcGIS.Core.CIM.CIMProportionalRenderer
    Requirements
