ArcGIS.Core.CIM Namespace / CIMProportionalRenderer Class
Properties Methods Events
    CIMProportionalRenderer Class Members
    The following tables list the members exposed by CIMProportionalRenderer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the additional authoring information used by the renderer.
    Public Property Gets or sets background symbol features are drawn with underneath the proportional symbols.
    Public Property Gets or sets the barrier weight used for graduated symbols to avoid labels.
    Public Property Gets or sets the default description.
    Public Property Gets or sets the default label.
    Public Property Gets or sets the default symbol.
    Public Property Gets or sets the custom patch for the default symbol.
    Public Property Gets or sets the patch shape for the default symbol.
    Public Property Gets or sets a value indicating whether or not to draw proportional symbols for polygon features above all layers.
    Public Property Gets or sets the exclusion clause.
    Public Property Gets or sets the exclusion description.
    Public Property Gets or sets the exclusion label.
    Public Property Gets or sets the exclusion symbol.
    Public Property Gets or sets the custom patch for the exclusion symbol.
    Public Property Gets or sets the patch shape for the exclusion symbol.
    Public Property Gets or sets the field the renderer is using.
    Public Property Gets or sets a value indicating whether or not to use Flannery compensation.
    Public Property Gets or sets the heading.
    Public Property Gets or sets the legend symbol count.
    Public Property Gets or sets the maximum data value.
    Public Property Gets or sets the minimum data value.
    Public Property Gets or sets the minimum symbol.
    Public Property Gets or sets the normalization field.
    Public Property Gets or sets the normalization total.
    Public Property Gets or sets the normalization type.
    Public Property Gets or sets the maximum number of records to sample.
    Public Property Gets or sets a value indicating whether or not to show classes in ascending order.
    Public Property Gets or sets the unit symbolization.
    Public Property Gets or sets a value indicating whether or not to use the default symbol.
    Public Property Gets or sets a value indicating whether or not to use the exclusion symbol.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number. When both Fields and ValueExpressionInfo are present ValueExpressionInfo is used.
    Public Property Gets or sets the visual variables.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMProportionalRenderer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMProportionalRenderer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMProportionalRenderer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
