ArcGIS.Core.CIM Namespace / esriGeometryType Enumeration
Example Example
    The available kinds of geometry objects.
    Syntax
    Members
    MemberDescription
    esriGeometryAny Any of the geometry coclass types.
    esriGeometryBag A collection of geometries of arbitrary type.
    esriGeometryBezier3Curve A third degree bezier curve (four control points).
    esriGeometryCircularArc A portion of the boundary of a circle.
    esriGeometryEllipticArc A portion of the boundary of an ellipse.
    esriGeometryEnvelope A rectangle indicating the spatial extent of another geometry.
    esriGeometryLine A straight line segment between two points.
    esriGeometryMultiPatch A collection of surface patches.
    esriGeometryMultipoint An ordered collection of points.
    esriGeometryNull A geometry of unknown type.
    esriGeometryPath A connected sequence of segments.
    esriGeometryPoint A single zero dimensional geometry.
    esriGeometryPolygon A collection of rings ordered by their containment relationship.
    esriGeometryPolyline An ordered collection of paths.
    esriGeometryRay An infinite, one-directional line extending from an origin point.
    esriGeometryRing An area bounded by one closed path.
    esriGeometrySphere A complete 3 dimensional sphere.
    esriGeometryTriangleFan A surface patch of triangles defined by the first point and two consecutive points.
    esriGeometryTriangles A surface patch of triangles defined by non-overlapping sets of three consecutive points each.
    esriGeometryTriangleStrip A surface patch of triangles defined by three consecutive points.
    Example
    Get a layer of a certain geometry type
        //Get an existing Layer. This layer has a symbol you want to use in a new layer.
        var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                .Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint).FirstOrDefault();
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.esriGeometryType
    Requirements
