Public Class CIMMaplexDictionaryEntry Inherits CIMObject Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMMaplexDictionaryEntry : CIMObject, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
//Get the map's definition
//Note: needs to be called on the MCT
var mapDefn = MapView.Active.Map.GetDefinition();
//Get the Map's Maplex labelling engine properties
var mapDefnPlacementProps = mapDefn.GeneralPlacementProperties as CIMMaplexGeneralPlacementProperties;
//Define the abbreviations we need in an array
List<CIMMaplexDictionaryEntry> abbreviationDictionary = new List<CIMMaplexDictionaryEntry>
new CIMMaplexDictionaryEntry {
Abbreviation = "Hts",
Text = "Heights",
MaplexAbbreviationType = MaplexAbbreviationType.Ending
Abbreviation = "Ct",
Text = "Text",
//etc
//The Maplex Dictionary - can hold multiple Abbreviation collections
var maplexDictionary = new List<CIMMaplexDictionary>
new CIMMaplexDictionary {
Name = "NameEndingsAbbreviations",
MaplexDictionary = abbreviationDictionary.ToArray()
//Set the Maplex Label Engine Dictionary property to the Maplex Dictionary collection created above.
mapDefnPlacementProps.Dictionaries = maplexDictionary.ToArray();
//Set the Map definition
MapView.Active.Map.SetDefinition(mapDefn);
//Creates Abbreviation dictionary and adds to Map Definition
//Refer to the " Create Abbreviation Dictionary in the Map Definition to a layer" snippet above
//Get the layer's definition
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//Modify label Placement props to use abbreviation dictionary
CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
//Get the dictionary from the map definition
theLabelClass.MaplexLabelPlacementProperties.DictionaryName = "NameEndingsAbbreviations";
theLabelClass.MaplexLabelPlacementProperties.CanAbbreviateLabel = true;
theLabelClass.MaplexLabelPlacementProperties.CanStackLabel = false;
//Set the labelClasses back
lyrDefn.LabelClasses = listLabelClasses.ToArray();
//set the layer's definition
featureLayer.SetDefinition(lyrDefn);
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMMaplexDictionaryEntry
