ArcGIS.Core.CIM Namespace / CIMRasterColorizer Class
Members Example
    Represents a raster colorizer.
    Object Model
    CIMRasterColorizer ClassCIMColor Class
    Syntax
    Example
    Update the raster colorizer on a raster layer
        // Get the colorizer from the raster layer.
        //Note: needs to be called on the QueuedTask
        CIMRasterColorizer rasterColorizer = rasterLayer.GetColorizer();
        // Update raster colorizer properties.
        rasterColorizer.Brightness = 10;
        rasterColorizer.Contrast = -5;
        rasterColorizer.ResamplingType = RasterResamplingType.NearestNeighbor;
        // Update the raster layer with the changed colorizer.
        rasterLayer.SetColorizer(rasterColorizer);
    Update the raster colorizer on a mosaic layer
        // Get the image sub-layer from the mosaic layer.
        ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
        // Get the colorizer from the image sub-layer.
        CIMRasterColorizer rasterColorizer = mosaicImageSubLayer.GetColorizer();
        // Update the image sub-layer with the changed colorizer.
        mosaicImageSubLayer.SetColorizer(rasterColorizer);
    Update the raster colorizer on an image service layer
        // Get the colorizer from the image service layer.
        CIMRasterColorizer rasterColorizer = imageServiceLayer.GetColorizer();
        // Update the colorizer properties.
        // Update the image service layer with the changed colorizer.
        imageServiceLayer.SetColorizer(rasterColorizer);
    Update the RGB colorizer on an image service layer
        CIMRasterColorizer rColorizer = imageServiceLayer.GetColorizer();
        // Check if the colorizer is an RGB colorizer.
        if (rColorizer is CIMRasterRGBColorizer rasterRGBColorizer)
            // Update RGB colorizer properties.
            rasterRGBColorizer.StretchType = RasterStretchType.ESRI;
            imageServiceLayer.SetColorizer((CIMRasterColorizer)rasterRGBColorizer);
    Inheritance Hierarchy
    Requirements
