public class CIMRasterStretchColorizer : CIMRasterColorizer, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
Public Class CIMRasterStretchColorizer Inherits CIMRasterColorizer Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
await QueuedTask.Run(async () =>
// Check if the Stretch colorizer can be applied to the raster layer.
if (rasterLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
// Create a new Stretch Colorizer Definition using the default constructor.
StretchColorizerDefinition stretchColorizerDef_default = new StretchColorizerDefinition();
// Create a new Stretch colorizer using the colorizer definition created above.
CIMRasterStretchColorizer newStretchColorizer_default =
await rasterLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
// Set the new colorizer on the raster layer.
rasterLayer.SetColorizer(newStretchColorizer_default);
//Get a color ramp from a style
var project = Project.Current;
StyleProjectItem ArcGISColorsStyleItem =
project.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS Colors");
var colorRamps = ArcGISColorsStyleItem.SearchColorRamps("Heat Map 4 - Semitransparent");
CIMColorRamp colorRampToUse = colorRampList[0].ColorRamp;
// Create a new Stretch Colorizer Definition specifying parameters
// for band index, stretch type, gamma and color ramp.
StretchColorizerDefinition stretchColorizerDef_custom =
new StretchColorizerDefinition(1, RasterStretchType.ESRI, 2, colorRamp);
// Create a new stretch colorizer using the colorizer definition created above.
CIMRasterStretchColorizer newStretchColorizer_custom =
await rasterLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
rasterLayer.SetColorizer(newStretchColorizer_custom);
// Get the image sub-layer from the mosaic layer.
ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
// Check if the Stretch colorizer can be applied to the image sub-layer.
if (mosaicImageSubLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
// Set the new colorizer on the image sub-layer.
mosaicImageSubLayer.SetColorizer(newStretchColorizer_default);
// Create a new Stretch colorizer definition specifying parameters
await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
mosaicImageSubLayer.SetColorizer(newStretchColorizer_custom);
// Check if the Stretch colorizer can be applied to the image service layer.
if (imageServiceLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
// Set the new colorizer on the image service layer.
imageServiceLayer.SetColorizer(newStretchColorizer_default);
await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
imageServiceLayer.SetColorizer(newStretchColorizer_custom);
//If a raster dataset has statistics, you can create a raster layer and get these statistics by accessing the colorizer. var rasterStatisticsMapView = MapView.Active; if (rasterStatisticsMapView == null) return; await QueuedTask.Run(() => { //Accessing the raster layer var lyr = rasterStatisticsMapView.Map.GetLayersAsFlattenedList().OfType<BasicRasterLayer>().FirstOrDefault(); //Getting the colorizer var colorizer = lyr.GetColorizer() as CIMRasterStretchColorizer; //Accessing the statistics var stats = colorizer.StretchStats; var max = stats.max; var min = stats.min; });
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMRasterColorizer
ArcGIS.Core.CIM.CIMRasterStretchColorizer
