ArcGIS.Core.CIM Namespace / CIMRasterStretchColorizer Class
Properties Methods Events
    CIMRasterStretchColorizer Class Members
    The following tables list the members exposed by CIMRasterStretchColorizer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the background color.
    Public Property Gets or sets the background value.
    Public Property Gets or sets the band index of the band being stretched.
    Public Property Gets or sets the brightness value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the color ramp.
    Public Property Gets or sets the color ramp scheme name.
    Public Property Gets or sets the contrast value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the color stretch custom max.
    Public Property Gets or sets the color stretch custom min.
    Public Property Gets or sets a value indicating whether or not to display the background.
    Public Property Gets or sets the Esri stretch contrast parameter.
    Public Property Gets or sets the Esri stretch mean parameter.
    Public Property Gets or sets the gamma value.
    Public Property Gets or sets the legend heading.
    Public Property Gets or sets the edit info defining the raster histogram customization.
    Public Property Gets or sets a value indicating whether or not to invert the stretch.
    Public Property Gets or sets a long array of lookup values.
    Public Property Gets or sets the maximum percent.
    Public Property Gets or sets the minimum percent.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the no data color. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the number format applied to the display of values.
    Public Property Gets or sets the raster resampling type. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the sharpening value.
    Public Property Gets or sets the statistics for histogram specification stretch.
    Public Property Gets or sets the standard deviation parameter value.
    Public Property Gets or sets the type of raster stretch statistics.
    Public Property Gets or sets the raster stretch classes.
    Public Property Gets or sets the raster stretch statistics.
    Public Property Gets or sets the raster stretch type.
    Public Property Gets or sets a value indicating whether or not to use advanced labeling.
    Public Property Gets or sets a value indicating whether or not to use custom stretch minimum and maximum.
    Public Property Gets or sets a value indicating whether or not to use gamma stretch.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRasterStretchColorizer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRasterStretchColorizer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRasterStretchColorizer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
