ArcGIS.Core.CIM Namespace / CIMRasterStretchColorizer Class / Invert Property
Example
    Invert Property (CIMRasterStretchColorizer)
    Gets or sets a value indicating whether or not to invert the stretch.
    Syntax
    Public Property Invert As Boolean
    public bool Invert {get; set;}
    Example
    Create a new colorizer based on a default colorizer definition and apply it to the raster layer
        // Check if the Stretch colorizer can be applied to the raster layer.
        //Note: needs to be called on the QueuedTask
        if (rasterLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
            // Create a new Stretch Colorizer Definition using the default constructor.
            StretchColorizerDefinition stretchColorizerDef_default = new StretchColorizerDefinition();
            // Create a new Stretch colorizer using the colorizer definition created above.
            CIMRasterStretchColorizer newStretchColorizer_default =
            await rasterLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
            // Set the new colorizer on the raster layer.
            rasterLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the raster layer
        //Get a color ramp from a style
        StyleProjectItem ArcGISColorsStyleItem =
              Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS Colors");
        var colorRamps = ArcGISColorsStyleItem.SearchColorRamps("Heat Map 4 - Semitransparent");
        CIMColorRamp colorRampToUse = colorRampList[0].ColorRamp;
            // Create a new Stretch Colorizer Definition specifying parameters
            // for band index, stretch type, gamma and color ramp.
            StretchColorizerDefinition stretchColorizerDef_custom =
        new StretchColorizerDefinition(1, RasterStretchType.ESRI, 2, colorRamp);
            // Create a new stretch colorizer using the colorizer definition created above.
            CIMRasterStretchColorizer newStretchColorizer_custom =
        await rasterLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
            rasterLayer.SetColorizer(newStretchColorizer_custom);
    Create a new colorizer based on a default colorizer definition and apply it to the mosaic layer
        // Get the image sub-layer from the mosaic layer.
        ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
        // Check if the Stretch colorizer can be applied to the image sub-layer.
        if (mosaicImageSubLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
        await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
            // Set the new colorizer on the image sub-layer.
            mosaicImageSubLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the mosaic layer
            // Create a new Stretch colorizer definition specifying parameters
        await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
            mosaicImageSubLayer.SetColorizer(newStretchColorizer_custom);
    Create a new colorizer based on a default colorizer definition and apply it to the image service layer
        // Check if the Stretch colorizer can be applied to the image service layer.
        if (imageServiceLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
        await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
            // Set the new colorizer on the image service layer.
            imageServiceLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the image service layer
        await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
            imageServiceLayer.SetColorizer(newStretchColorizer_custom);
    Requirements
