public StatsHistogram StretchStats {get; set;}
Public Property StretchStats As StatsHistogram
//If a raster dataset has statistics, you can create a raster layer and get these statistics by accessing the colorizer. var rasterStatisticsMapView = MapView.Active; if (rasterStatisticsMapView == null) return; await QueuedTask.Run(() => { //Accessing the raster layer var lyr = rasterStatisticsMapView.Map.GetLayersAsFlattenedList().OfType<BasicRasterLayer>().FirstOrDefault(); //Getting the colorizer var colorizer = lyr.GetColorizer() as CIMRasterStretchColorizer; //Accessing the statistics var stats = colorizer.StretchStats; var max = stats.max; var min = stats.min; });
