ArcGIS.Core.CIM Namespace / StatsHistogram Class
Members Example
    Represents a raster statistics and histogram class.
    Object Model
    StatsHistogram ClassStatsHistogram Class
    Syntax
    Example
    Calculate Raster statistics
    //If a raster dataset has statistics, you can create a raster layer and get these statistics by accessing the colorizer.
    await QueuedTask.Run(() =>
      //Accessing the raster layer
      var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<BasicRasterLayer>().FirstOrDefault();
      //Getting the colorizer
      var colorizer = lyr.GetColorizer() as CIMRasterStretchColorizer;
      //Accessing the statistics
      var stats = colorizer.StretchStats;
      var max = stats.max;
      var min = stats.min;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.StatsHistogram
    Requirements
