ArcGIS.Core.CIM Namespace / CIMRasterColorizer Class / Brightness Property
Example
    Brightness Property (CIMRasterColorizer)
    Gets or sets the brightness value.
    Syntax
    public int Brightness {get; set;}
    Public Property Brightness As Integer
    Example
    Update the raster colorizer on a raster layer
      await QueuedTask.Run(() =>
        // Get the colorizer from the raster layer.
        CIMRasterColorizer rasterColorizer = rasterLayer.GetColorizer();
        // Update raster colorizer properties.
        rasterColorizer.Brightness = 10;
        rasterColorizer.Contrast = -5;
        rasterColorizer.ResamplingType = RasterResamplingType.NearestNeighbor;
        // Update the raster layer with the changed colorizer.
        rasterLayer.SetColorizer(rasterColorizer);
    Update the raster colorizer on a mosaic layer
      // Get the image sub-layer from the mosaic layer.
      ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
      // Get the colorizer from the image sub-layer.
      CIMRasterColorizer rasterColorizer = mosaicImageSubLayer.GetColorizer();
      // Update the image sub-layer with the changed colorizer.
      mosaicImageSubLayer.SetColorizer(rasterColorizer);
    Update the raster colorizer on an image service layer
      // Get the colorizer from the image service layer.
      CIMRasterColorizer rasterColorizer = imageServiceLayer.GetColorizer();
      // Update the colorizer properties.
      // Update the image service layer with the changed colorizer.
      imageServiceLayer.SetColorizer(rasterColorizer);
    Requirements
