ArcGIS.Core.CIM Namespace / CIMReportField Class
Members Example
    Represents a field in a report.
    Object Model
    CIMReportField ClassCIMReportField ClassCIMReportField Class
    Syntax
    Example
    Create report
      //Note: Call within QueuedTask.Run()
      //The fields in the datasource used for the report
      //This uses a US Cities dataset
      var listFields = new List<CIMReportField> {
              //Grouping should be the first field
              new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
              new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
              new CIMReportField{Name = "POP1990", FieldOrder = 2, },
      //Definition query to use for the data source
      var defQuery = "STATE_NAME LIKE 'C%'";
      //Define the Datasource
      var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
      //The CIMPage defintion - page size, units, etc
      var cimReportPage = new CIMPage
        Height = 11,
        StretchElements = false,
        Width = 6.5,
        ShowRulers = true,
        ShowGuides = true,
        Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
        Units = LinearUnit.Inches
      //Report template
      var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
      var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
      //Report Styling
      var reportStyles = await ReportStylingManager.GetStylingsAsync();
      var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
      //Field Statistics
      var fieldStatisticsList = new List<ReportFieldStatistic> {
              new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
              //Note: NoStatistics option for FieldStatisticsFlag is not supported.
      var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
    Create a new field in the report
      //This is the gap between two fields
      double fieldIncrement = 0.9388875113593206276389;
      //On the QueuedTask
      //New field to add.
      var newReportField = new CIMReportField
        Name = "POP1990",
        FieldOrder = 2,
      //Get the "ReportSection element"
      var mainReportSection = report.Elements.OfType<ReportSection>().FirstOrDefault();
      if (mainReportSection == null) return;
      //Get the "ReportDetails" within the ReportSectionElement. ReportDetails is where "fields" are.
      var reportDetailsSection = mainReportSection?.Elements.OfType<ReportDetails>().FirstOrDefault();
      if (reportDetailsSection == null) return;
      //Within ReportDetails find the envelope that encloses a field.
      //We get the first CIMParagraphTextGraphic in the collection so that we can add the new field next to it.
      var lastFieldGraphic = reportDetailsSection.Elements.FirstOrDefault((r) =>
        var gr = r as GraphicElement;
        if (gr == null) return false;
        return (gr.GetGraphic() is CIMParagraphTextGraphic ? true : false);
      //Get the Envelope of the last field
      var graphicBounds = lastFieldGraphic.GetBounds();
      //Min and Max values of the envelope
      var xMinOfFieldEnvelope = graphicBounds.XMin;
      var yMinOfFieldEnvelope = graphicBounds.YMin;
      var xMaxOfFieldEnvelope = graphicBounds.XMax;
      var YMaxOfFieldEnvelope = graphicBounds.YMax;
      //create the new Envelope to be offset from the existing field
      MapPoint newMinPoint = MapPointBuilderEx.CreateMapPoint(xMinOfFieldEnvelope + fieldIncrement, yMinOfFieldEnvelope);
      MapPoint newMaxPoint = MapPointBuilderEx.CreateMapPoint(xMaxOfFieldEnvelope + fieldIncrement, YMaxOfFieldEnvelope);
      Envelope newFieldEnvelope = EnvelopeBuilderEx.CreateEnvelope(newMinPoint, newMaxPoint);
      //Create field
      GraphicElement fieldGraphic = ReportElementFactory.Instance.CreateFieldValueTextElement(reportDetailsSection, newFieldEnvelope, newReportField);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMTableField
             ArcGIS.Core.CIM.CIMReportField
    Requirements
