ArcGIS.Core.CIM Namespace / CIMLineSymbol Class
Members Example
    CIMLineSymbol Class
    Represents a line symbol which is used to draw polyline features or graphics.
    Object Model
    CIMLineSymbol ClassCIMLineSymbol ClassCIMLineSymbol Class
    Syntax
    Example
    Create Lasso Line, Freehand Graphic Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      List<Coordinate2D> plCoords = new List<Coordinate2D>();
      plCoords.Add(new Coordinate2D(1.5, 10.5));
      plCoords.Add(new Coordinate2D(1.25, 9.5));
      plCoords.Add(new Coordinate2D(1, 10.5));
      plCoords.Add(new Coordinate2D(0.75, 9.5));
      plCoords.Add(new Coordinate2D(0.5, 10.5));
      plCoords.Add(new Coordinate2D(0.5, 1));
      plCoords.Add(new Coordinate2D(0.75, 2));
      plCoords.Add(new Coordinate2D(1, 1));
      Polyline linePl = PolylineBuilderEx.CreatePolyline(plCoords);
      //Set symbology, create and add element to layout
      CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(
                ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Solid);
      //var graphic = GraphicFactory.Instance.CreateShapeGraphic(linePl, lineSym);
      var ge = ElementFactory.Instance.CreateGraphicElement(
                              layout, linePl, lineSym, "New Freehand");
    Create line graphic with symbology
      //Create a simple 2D line graphic and apply an existing line
      //style item as the symbology.
      //Build 2d line geometry
      plCoords.Add(new Coordinate2D(1, 8.5));
      plCoords.Add(new Coordinate2D(1.66, 9));
      plCoords.Add(new Coordinate2D(2.33, 8.1));
      plCoords.Add(new Coordinate2D(3, 8.5));
      //(optionally) Reference a line symbol in a style
      StyleProjectItem lnStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
                                    .FirstOrDefault(item => item.Name == "ArcGIS 2D");
      SymbolStyleItem lnSymStyleItm = lnStylePrjItm.SearchSymbols(
                                    StyleItemType.LineSymbol, "Line with 2 Markers")[0];
      CIMLineSymbol lineSym = lnSymStyleItm.Symbol as CIMLineSymbol;
      lineSym.SetSize(20);
      //An alternative simple symbol is also commented out below.
      //This would eliminate the four optional lines of code above that
      //reference a style.
      //CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(
      //         ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
      GraphicElement lineElm = ElementFactory.Instance.CreateGraphicElement(
                                                  layout, linePl, lineSym);
      lineElm.SetName("New Line");
    How to construct a line symbol of specific color, size and line style
        CIMLineSymbol lineSymbol = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
    How to construct a line symbol from a stroke
        CIMStroke stroke = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 2.0);
        CIMLineSymbol lineSymbolFromStroke = SymbolFactory.Instance.ConstructLineSymbol(stroke);
    How to construct a multilayer line symbol with circle markers on the line ends
        //Note: Needs QueuedTask to run
        var lineStrokeRed = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 4.0);
        var markerCircle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Circle);
        markerCircle.MarkerPlacement = new CIMMarkerPlacementOnVertices()
            AngleToLine = true,
            PlaceOnEndPoints = true,
            Offset = 0
        var lineSymbolWithCircles = new CIMLineSymbol()
            SymbolLayers = new CIMSymbolLayer[2] { markerCircle, lineStrokeRed }
    How to construct a multilayer line symbol with an arrow head on the end
          var markerTriangle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Triangle);
          markerTriangle.Rotation = -90; // or -90
          markerTriangle.MarkerPlacement = new CIMMarkerPlacementOnLine() { AngleToLine = true, RelativeTo = PlacementOnLineRelativeTo.LineEnd };
          var lineSymbolWithArrow = new CIMLineSymbol()
              SymbolLayers = new CIMSymbolLayer[2] { markerTriangle,
              SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 2)
    Markers placed at a 45 degree angle
    /// <summary>
    /// Create a line symbol with the markers placed at a 45 degree angle. <br/>
    /// ![LineSymbolAngleMarker](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/line-marker-angle.png)
    /// </summary>
      //Create a line symbol with the markers placed at a 45 degree angle.
      //Create a marker from the "|" character.  This is the marker that will be used to render the line layer.
      //Note: Run withing QueuedTask
      var lineMarker = SymbolFactory.Instance.ConstructMarker(124, "Agency FB", "Regular", 12);
      //Default line symbol which will be modified
      CIMLineSymbol lineSymbolWithMarkersAtAngle = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlackRGB, 2, SimpleLineStyle.Solid);
      //Modifying the marker to align with line
      //First define "markerplacement"
      CIMMarkerPlacementAlongLineSameSize markerPlacement = new CIMMarkerPlacementAlongLineSameSize()
        AngleToLine = true,
        PlacementTemplate = new double[] { 5 }
      //assign the markerplacement to the marker
      lineMarker.MarkerPlacement = markerPlacement;
      //angle the marker if needed
      lineMarker.Rotation = 45;
      //assign the marker as a layer to the line symbol
      lineSymbolWithMarkersAtAngle.SymbolLayers[0] = lineMarker;
    Dash line with two markers - Method I
    /// <summary>
    /// Create a line symbol with a dash and two markers.<br/>
    /// This line symbol comprises three symbol layers listed below:
    /// 1. A solid stroke that has dashes.
    /// 1. A circle marker.
    /// 1. A square marker.
    /// ![LineSymbolTwoMarkers](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/line-dash-two-markers.png)
    /// </summary>
      //Create a line symbol with a dash and two markers.
      CIMLineSymbol dash2MarkersLine = new CIMLineSymbol();
      var mySymbolLyrs = new CIMSymbolLayer[]
                  new CIMSolidStroke()
                      Color = ColorFactory.Instance.BlackRGB,
                      Enable = true,
                      ColorLocked = true,
                      CapStyle = LineCapStyle.Round,
                      JoinStyle = LineJoinStyle.Round,
                      LineStyle3D = Simple3DLineStyle.Strip,
                      MiterLimit = 10,
                      Width = 1,
                      CloseCaps3D = false,
                      Effects = new CIMGeometricEffect[]
                          new CIMGeometricEffectDashes()
                              CustomEndingOffset = 0,
                              DashTemplate = new double[] {20, 10, 20, 10},
                              LineDashEnding = LineDashEnding.HalfPattern,
                              OffsetAlongLine = 0,
                              ControlPointEnding = LineDashEnding.NoConstraint
                          new CIMGeometricEffectOffset()
                              Method = GeometricEffectOffsetMethod.Bevelled,
                              Offset = 0,
                              Option = GeometricEffectOffsetOption.Fast
                  CreateCircleMarkerPerSpecs(),
                  CreateSquareMarkerPerSpecs()
      dash2MarkersLine.SymbolLayers = mySymbolLyrs;
      static CIMMarker CreateCircleMarkerPerSpecs()
        var circleMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlackRGB, 5, SimpleMarkerStyle.Circle) as CIMVectorMarker;
          AngleToLine = true,
          Offset = 0,
          Endings = PlacementEndings.Custom,
          OffsetAlongLine = 15,
          PlacementTemplate = new double[] { 60 }
        circleMarker.MarkerPlacement = markerPlacement;
        return circleMarker;
      static CIMMarker CreateSquareMarkerPerSpecs()
        var squareMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlueRGB, 5, SimpleMarkerStyle.Square) as CIMVectorMarker;
        CIMMarkerPlacementAlongLineSameSize markerPlacement2 = new CIMMarkerPlacementAlongLineSameSize()
          AngleToLine = true,
          OffsetAlongLine = 45,
          PlacementTemplate = new double[] { 60 },
        squareMarker.MarkerPlacement = markerPlacement2;
        return squareMarker;
    Dash line with two markers - Method II
    /// <summary>
    /// Create a line symbol with a dash and two markers. <br/>
    /// In this pattern of creating this symbol, a [CIMVectorMarker](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic6176.html) object is created as a new [CIMSymbolLayer](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic5503.html).
    /// The circle and square markers created by [ContructMarker](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic12350.html) method is then assigned to the [MarkerGraphics](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic6188.html) property of the CIMVectorMarker.
    /// When using this method, the CIMVectorMarker's [Frame](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic6187.html) property needs to be set to the [CIMMarker](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic3264.html) object's Frame.
    /// Similarly, the CIMVectorMarker's [Size](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic3284.html) property needs to be set to the CIMMarker object's size.
    /// </summary>
      //default line symbol that will get modified.
      //circle marker to be used in our line symbol as a layer
      //Create the array of layers that make the new line symbol
      CIMSymbolLayer[] mySymbolLyrs =
                  new CIMSolidStroke() //dash line
                      Enable = true,
                      ColorLocked = true,
                      MiterLimit = 10,
                      Width = 1,
                              Offset = 0,
                  new CIMVectorMarker() //circle marker
                      MarkerGraphics = circleMarker.MarkerGraphics,
                      Frame = circleMarker.Frame, //need to match the CIMVector marker's frame to the circleMarker's frame.
                      Size = circleMarker.Size,    //need to match the CIMVector marker's size to the circleMarker's size.
                     MarkerPlacement = new CIMMarkerPlacementAlongLineSameSize()
                         AngleToLine = true,
                         Offset = 0,
                         PlacementTemplate = new double[] {60},
                  new CIMVectorMarker() //square marker
                     MarkerGraphics = squareMarker.MarkerGraphics,
                     Frame = squareMarker.Frame, //need to match the CIMVector marker's frame to the squareMarker frame.
                     Size = squareMarker.Size, //need to match the CIMVector marker's size to the squareMarker size.
                         AngleToLine = true,
    Diagonal cross hatch fill
    /// <summary>
    /// Create a polygon symbol with a diagonal cross hatch fill. <br/>
    /// ![PolygonSymbolDiagonalCrossHatch](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-diagonal-crosshatch.png)
    /// </summary>
      var trans = 50.0;//semi transparent
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(0, 0, 0, trans), 2.0, SimpleLineStyle.Solid);
      //Stroke for the fill
      var solid = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(255, 0, 0, trans), 1.0, SimpleLineStyle.Solid);
      //Mimic cross hatch
      CIMFill[] diagonalCross =
                  new CIMHatchFill() {
                      Enable = true,
                      Rotation = 45.0,
                      Separation = 5.0,
                      LineSymbol = new CIMLineSymbol() { SymbolLayers = new CIMSymbolLayer[1] { solid } }
                      Enable = true,
                      Rotation = -45.0,
                      Separation = 5.0,
      List<CIMSymbolLayer> symbolLayers =
          outline, .. diagonalCross
      //This is the polygon symbol with a diagonal cross hatch fill
      CIMPolygonSymbol diagonalCrossHatchFillSymbol = new()
        SymbolLayers = [.. symbolLayers]
      //To apply the symbol to a polygon feature layer
      //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = diagonalCrossHatchFillSymbol.MakeSymbolReference();
      //theLayer.SetRenderer(renderer);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMSymbol
             ArcGIS.Core.CIM.CIMMultiLayerSymbol
                ArcGIS.Core.CIM.CIMLineSymbol
    Requirements
