ArcGIS.Core.CIM Namespace / ClassificationMethod Enumeration
Example Example
    Methods used for classifying numerical fields for graduated symbology.
    Syntax
    Members
    MemberDescription
    DefinedInterval Defined interval.
    EqualInterval Equal interval.
    GeometricalInterval Geometrical interval.
    Manual Manual.
    NaturalBreaks Natural breaks.
    Quantile Quantile.
    StandardDeviation Standard deviation.
    Example
    Create a feature layer with class breaks renderer with defaults
        var featureLayerCreationParams = new FeatureLayerCreationParams(new Uri(@"c:\data\countydata.gdb\counties"))
            Name = "Population Density (sq mi) Year 2010",
            RendererDefinition = new GraduatedColorsRendererDefinition("POP10_SQMI")
        LayerFactory.Instance.CreateLayer<FeatureLayer>(
          featureLayerCreationParams,
          MapView.Active.Map
        string colorBrewerSchemesName = "ColorBrewer Schemes (RGB)";
        StyleProjectItem colorBrewerStyle = Project.Current.GetItems<StyleProjectItem>().First(s => s.Name == colorBrewerSchemesName);
        string colorRampName = "Greens (Continuous)";
        //Note: Needs QueuedTask to run
        IList<ColorRampStyleItem> colorRampListFromTheStyle = colorBrewerStyle.SearchColorRamps(colorRampName);
        ColorRampStyleItem colorRampFound = colorRampList[0];
        GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
            ClassificationField = "CROP_ACR07",
            ClassificationMethod = ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks,
            BreakCount = 6,
            ColorRamp = colorRampFound.ColorRamp,
            SymbolTemplate = SymbolFactory.Instance.ConstructPolygonSymbol(
                                  ColorFactory.Instance.GreenRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
            ExclusionClause = "CROP_ACR07 = -99",
            ExclusionSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                                  ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
            ExclusionLabel = "No yield",
        var featureLayerCreationParams = new FeatureLayerCreationParams((new Uri(@"c:\Data\CountyData.gdb\Counties")))
            Name = "Crop",
            RendererDefinition = gcDef
        LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerCreationParams, MapView.Active.Map);
    Elevation Node Renderer - Defined Interval
      // applies to TIN layers only
      var defiendIntervalNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      defiendIntervalNodeRendererDef.ClassificationMethod = ClassificationMethod.DefinedInterval;
      defiendIntervalNodeRendererDef.IntervalSize = 4;
      defiendIntervalNodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
      // Note: Needs QueuedTask to run
        if (tinLayer.CanCreateRenderer(defiendIntervalNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(defiendIntervalNodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Elevation Node Renderer - Standard Deviation
      var stdDevNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      stdDevNodeRendererDef.ClassificationMethod = ClassificationMethod.StandardDeviation;
      stdDevNodeRendererDef.DeviationInterval = StandardDeviationInterval.OneHalf;
      stdDevNodeRendererDef.ColorRamp = ColorFactory.Instance.GetColorRamp("Cyan to Purple");
        if (tinLayer.CanCreateRenderer(stdDevNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(stdDevNodeRendererDef);
    Slope Face Renderer - Quantile
      var slopeFaceClassBreaksQuantile = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      slopeFaceClassBreaksQuantile.ClassificationMethod = ClassificationMethod.Quantile;
      // accept default breakCount, symbolTemplate, color ramp
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksQuantile))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksQuantile);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
    LAS Points Classified Elevation Renderer
      var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
      lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
      // increase the symbol size by a factor
      lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
    Requirements
