ArcGIS.Core.CIM Namespace / CIMBackgroundCallout Class
Members Example
    Represents a background callout which draws a callout with an optional polygon background and leader line.
    Object Model
    CIMBackgroundCallout ClassCIMLineSymbol ClassCIMPolygonSymbol ClassCIMBackgroundCallout ClassCIMBackgroundCallout ClassCIMLineSymbol ClassCIMTextMargin Class
    Syntax
    Example
    Snippet Creates a background callout text symbol
    /// <summary>
    /// Creates a solid fill background text symbol with an Accent bar and leader line.  The [CIMBackgroundCallout](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic474.html) created has a solid fill aqua polygon, with a black dash-dot-dash leader line and a solid accent bar.
    /// ![lineCallOut](https://ArcGIS.github.io/arcgis-pro-sdk/images/Labeling//background-callout.png)
    /// </summary>
      //Note: Run this code inside a QueuedTask
      var textSymbolBackgroundCallout = SymbolFactory.Instance.ConstructTextSymbol(ColorFactory.Instance.BlackRGB, 8, "Tahoma", "Bold");
      //Create a call out
      var backgroundCalloutSymbol = new CIMBackgroundCallout();
      //Leader line
      //Get a line symbol
      var lineSymbol = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlackRGB, 1, SimpleLineStyle.DashDotDot);
      //Create a solid fill polygon symbol for the callout.
      var aquaBackground = ColorFactory.Instance.CreateRGBColor(190, 255, 232, 100);
      var polySymbol = SymbolFactory.Instance.ConstructPolygonSymbol(aquaBackground, SimpleFillStyle.Solid);
      //assign the line to the callout
      backgroundCalloutSymbol.LeaderLineSymbol = lineSymbol;
      //Offset for the text
      textSymbolBackgroundCallout.OffsetX = 10;
      textSymbolBackgroundCallout.OffsetY = 10;
      //Assign the polygon to the background callout
      backgroundCalloutSymbol.BackgroundSymbol = polySymbol;
      //Accent bar
      var accentSymbol = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlackRGB, 2, SimpleLineStyle.Solid);
      backgroundCalloutSymbol.AccentBarSymbol = accentSymbol;
      //Set margins for the callout
      backgroundCalloutSymbol.Margin = new CIMTextMargin
        Left = 5,
        Right = 5,
        Top = 5,
        Bottom = 5
      //assign the callout to the textSymbol
      textSymbolBackgroundCallout.Callout = backgroundCalloutSymbol;
      //Refer to the snippet "How to apply a Text Symbol to labels of a layer" below to see how to apply this text symbol to a label class
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMCallout
             ArcGIS.Core.CIM.CIMLineCallout
                ArcGIS.Core.CIM.CIMBackgroundCallout
    Requirements
