ArcGIS.Core.CIM Namespace / CIMBackgroundCallout Class
Properties Methods Events
    CIMBackgroundCallout Class Members
    The following tables list the members exposed by CIMBackgroundCallout.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the symbol used to draw the accent bar. If null, the accent bar doesn't draw.
    Public Property Gets or sets the symbol used to draw the background. If null, the background doesn't draw.
    Public Property Gets or sets the gap (in points) between the text symbol and the beginning of the leader line. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the line symbol to draw leaders with. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the leader offset which is an offset value defining the distance (in points) between the anchor point and the beginning of the drawn leader. (Inherited from ArcGIS.Core.CIM.CIMCallout)
    Public Property Gets or sets the leader tolerance which is the closest distance (in points) to the text the anchor point can be for the callout to draw. (Inherited from ArcGIS.Core.CIM.CIMCallout)
    Public Property Gets or sets the style of line to generate when a Point leader is drawn defined by an enumeration value. Line leaders will always be drawn with their own geometry. (Inherited from ArcGIS.Core.CIM.CIMLineCallout)
    Public Property Gets or sets the text margin defining the space around the text that is accounted for in background creation.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMBackgroundCallout.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMBackgroundCallout with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMBackgroundCallout and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
