ArcGIS.Core.CIM Namespace / CIMLineGraphic Class
Members Example
    Represents a line graphic.
    Object Model
    CIMLineGraphic ClassCIMLineGraphic ClassCIMLineGraphic ClassPolyline ClassCIMSymbolReference Class
    Syntax
    Example
    Line Graphic Element using CIMGraphic
      // Note: must be called on the QueuedTask
        //On the QueuedTask
        //Place a line symbol using the extent's lower left and upper right corner.
        var extent = MapView.Active.Extent;
        //get the lower left corner of the extent
        var pointFromCoordinates = new Coordinate2D(extent.XMin, extent.YMin);
        //get the upper right corner of the extent
        var pointToCoordinates = new Coordinate2D(extent.XMax, extent.YMax);
        List<Coordinate2D> points = new List<Coordinate2D> { pointFromCoordinates, pointToCoordinates };
        //create the polyline
        var lineSegment = PolylineBuilderEx.CreatePolyline(points);
        //specify a symbol
        var line_symbol = SymbolFactory.Instance.ConstructLineSymbol(
                              ColorFactory.Instance.GreenRGB);
        //create a CIMGraphic
        var graphic = new CIMLineGraphic()
          Symbol = line_symbol.MakeSymbolReference(),
          Line = lineSegment,
        graphicsLayer.AddElement(graphic);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMGraphic
             ArcGIS.Core.CIM.CIMShapeGraphic
                ArcGIS.Core.CIM.CIMLineGraphic
    Requirements
