ArcGIS.Core.CIM Namespace / CIMGeometricEffectScale Class
Members
    Represents the rotate geometric effect which creates a dynamic line or polygon scaled by a specified factor. Vertices are moved in relation to the center point of a feature envelope. Values greater than 1 move vertices away from the center point. Values between 0 and 1 move vertices toward the center point. Values less than 0 draw an inverse dynamic line or polygon where the vertices have crossed to the other side of the center point.
    Object Model
    CIMGeometricEffectScale ClassCIMGeometricEffectScale ClassCIMGeometricEffectScale Class
    Syntax
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMGeometricEffect
             ArcGIS.Core.CIM.CIMGeometricEffectScale
    Requirements
