ArcGIS.Core.CIM Namespace / LASStretchType Enumeration
Example Example
    LAS stretch types.
    Syntax
    Members
    MemberDescription
    Custom Custom.
    DefaultFromSource Default from source.
    Histogram Histogram.
    MinimumMaximum Minimum Maximum.
    PercentMinMax Percent minimum maximum.
    StandardDeviations Standard deviations.
    Example
    LAS Points Elevation Stretch Renderer
      var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      // accept the defaults for color ramp, etc
      if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
        CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
        if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
          lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
      // OR use a stretch renderer with stretchType standard Deviations
      var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
      elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.LASStretchType
    Requirements
