ArcGIS.Core.CIM Namespace / GeometricEffectDonutMethod Enumeration
    Geometric effect donut methods.
    Syntax
    Members
    MemberDescription
    Bevelled Bevelled - follows the shortest straight path across a convex corner of the polygon.
    Mitered Mitered - matches the exact shape around a convex corner of the polygon.
    Rounded Rounded - follows a path of equal distance around a convex corner of the polygon.
    Square Square - follows a straight path across the corner of a line or polygon.
    TrueBuffer TrueBuffer - uses the buffer algorithm to follow a path around convex corners.
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.GeometricEffectDonutMethod
    Requirements
