ArcGIS.Core.CIM Namespace / CIMColorRamp Class
Members Example
    CIMColorRamp Class
    Supports color ramp schemes in the CIM model by providing low level access to properties common amongst all color ramp types.
    Object Model
    CIMColorRamp ClassCIMColorSpace Class
    Syntax
    Remarks
    This is the base color ramp type which provides access to the color space.
    Example
    How to apply a color ramp from a style to a feature layer
        List<string> fields = new List<string>() { "Field1" };
        //Note: Needs QueuedTask to run
        StyleProjectItem styleToUse =
          Project.Current.GetItems<StyleProjectItem>()
              .FirstOrDefault(s => s.Name == "ColorBrewer Schemes (RGB)");
        if (style == null) return;
        var colorRampListFound = styleToUse.SearchColorRamps("Red-Gray (10 Classes)");
        if (colorRampListFound == null || colorRampListFound.Count == 0) return;
        CIMColorRamp cimColorRamp = null;
        CIMRenderer renderer = null;
        cimColorRamp = colorRampListFound[0].ColorRamp;
        var rendererDef = new UniqueValueRendererDefinition(fields, null, cimColorRamp);
        renderer = featureLayer?.CreateRenderer(rendererDef);
        featureLayer?.SetRenderer(renderer);
    Create and Set a Stretch Renderer
      // Note: call within QueuedTask.Run()
        var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
                                PointCloudRendererType.StretchRenderer);
        var stretchDef = new PointCloudRendererDefinition(
          //Will be either ELEVATION or INTENSITY
          Field = fields[0]
        //Create the CIM Renderer
        var stretchRenderer = pointCloudSceneLayer.CreateRenderer(stretchDef)
                                            as CIMPointCloudStretchRenderer;
        //Apply a color ramp
        var style = Project.Current.GetItems<StyleProjectItem>()
                                        .First(s => s.Name == "ArcGIS Colors");
        var colorRamp = style.SearchColorRamps("").First();
        stretchRenderer.ColorRamp = colorRamp.ColorRamp;
        //Apply modulation
        stretchRenderer.ColorModulation = new CIMColorModulationInfo()
          MinValue = 0,
          MaxValue = 100
        //apply the renderer
        pointCloudSceneLayer.SetRenderer(stretchRenderer);
    Inheritance Hierarchy
    Requirements
