ArcGIS.Core.CIM Namespace / CIMGeometricEffectOffset Class
Members Example
    Represents the offset geometric effect which creates a dynamic line or polygon offset at a specified distance perpendicularly from a feature.
    Object Model
    CIMGeometricEffectOffset ClassCIMGeometricEffectOffset ClassCIMGeometricEffectOffset Class
    Syntax
    Example
    Dash line with two markers - Method I
    /// <summary>
    /// Create a line symbol with a dash and two markers.<br/>
    /// This line symbol comprises three symbol layers listed below:
    /// 1. A solid stroke that has dashes.
    /// 1. A circle marker.
    /// 1. A square marker.
    /// ![LineSymbolTwoMarkers](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/line-dash-two-markers.png)
    /// </summary>
      //Create a line symbol with a dash and two markers.
      //Note: Run withing QueuedTask
      CIMLineSymbol dash2MarkersLine = new CIMLineSymbol();
      var mySymbolLyrs = new CIMSymbolLayer[]
                  new CIMSolidStroke()
                      Color = ColorFactory.Instance.BlackRGB,
                      Enable = true,
                      ColorLocked = true,
                      CapStyle = LineCapStyle.Round,
                      JoinStyle = LineJoinStyle.Round,
                      LineStyle3D = Simple3DLineStyle.Strip,
                      MiterLimit = 10,
                      Width = 1,
                      CloseCaps3D = false,
                      Effects = new CIMGeometricEffect[]
                          new CIMGeometricEffectDashes()
                              CustomEndingOffset = 0,
                              DashTemplate = new double[] {20, 10, 20, 10},
                              LineDashEnding = LineDashEnding.HalfPattern,
                              OffsetAlongLine = 0,
                              ControlPointEnding = LineDashEnding.NoConstraint
                          new CIMGeometricEffectOffset()
                              Method = GeometricEffectOffsetMethod.Bevelled,
                              Offset = 0,
                              Option = GeometricEffectOffsetOption.Fast
                  CreateCircleMarkerPerSpecs(),
                  CreateSquareMarkerPerSpecs()
      dash2MarkersLine.SymbolLayers = mySymbolLyrs;
      static CIMMarker CreateCircleMarkerPerSpecs()
        var circleMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlackRGB, 5, SimpleMarkerStyle.Circle) as CIMVectorMarker;
        //Modifying the marker to align with line
        //First define "markerplacement"
        CIMMarkerPlacementAlongLineSameSize markerPlacement = new CIMMarkerPlacementAlongLineSameSize()
          AngleToLine = true,
          Offset = 0,
          Endings = PlacementEndings.Custom,
          OffsetAlongLine = 15,
          PlacementTemplate = new double[] { 60 }
        //assign the markerplacement to the marker
        circleMarker.MarkerPlacement = markerPlacement;
        return circleMarker;
      static CIMMarker CreateSquareMarkerPerSpecs()
        var squareMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlueRGB, 5, SimpleMarkerStyle.Square) as CIMVectorMarker;
        CIMMarkerPlacementAlongLineSameSize markerPlacement2 = new CIMMarkerPlacementAlongLineSameSize()
          AngleToLine = true,
          OffsetAlongLine = 45,
          PlacementTemplate = new double[] { 60 },
        squareMarker.MarkerPlacement = markerPlacement2;
        return squareMarker;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMGeometricEffect
             ArcGIS.Core.CIM.CIMGeometricEffectOffset
    Requirements
