ArcGIS.Core.CIM Namespace / CIMSimpleLineCallout Class
Members Example
    Represents a simple line callout for drawing basic leader lines.
    Object Model
    CIMSimpleLineCallout ClassCIMSimpleLineCallout ClassCIMSimpleLineCallout ClassCIMLineSymbol Class
    Syntax
    Example
    Snippet Creates a simple line callout text symbol
    /// <summary>
    /// Creates a simple line callout text symbol.  The [CIMSimpleLineCallout](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic2760.html) created is a dash-dot-dash line symbol with an offset of 10 from the geometry being labeled.
    /// ![lineCallOut](https://ArcGIS.github.io/arcgis-pro-sdk/images/Labeling/line-callout.png)
    /// </summary>
      //create a text symbol
      //Note: Run this code inside a QueuedTask
      var textSymbolCallOut = SymbolFactory.Instance.ConstructTextSymbol(ColorFactory.Instance.BlackRGB, 10, "Verdana", "Regular");
      //Create a line call out
      var lineCalloutSymbol = new CIMSimpleLineCallout();
      //Get a line symbol
      var lineSymbol = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlackRGB, 1, SimpleLineStyle.DashDotDot);
      //assign the line symbol to the callout
      lineCalloutSymbol.LineSymbol = lineSymbol;
      //Offset for the text
      textSymbolCallOut.OffsetX = 10;
      textSymbolCallOut.OffsetY = 10;
      //Assign the callout to the text symbol
      textSymbolCallOut.Callout = lineCalloutSymbol;
      //Refer to the snippet "How to apply a Text Symbol to labels of a layer" below to see how to apply this text symbol to a label class
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMCallout
             ArcGIS.Core.CIM.CIMSimpleLineCallout
    Requirements
