ArcGIS.Core.CIM Namespace / CIMTinNodeElevationRenderer Class
Members Example
    Represents a TIN node elevation renderer.
    Object Model
    CIMTinNodeElevationRenderer ClassCIMTinNodeElevationRenderer ClassCIMColorRamp ClassCIMTinNodeElevationRenderer ClassCIMNumberFormat ClassCIMSymbolReference Class
    Syntax
    Example
    Elevation Node Renderer - Equal Breaks
      // applies to TIN layers only
      var equalBreaksNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      equalBreaksNodeRendererDef.BreakCount = 7;
      // Note: Needs QueuedTask to run
        if (tinLayer.CanCreateRenderer(equalBreaksNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(equalBreaksNodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Elevation Node Renderer - Defined Interval
      var defiendIntervalNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      defiendIntervalNodeRendererDef.ClassificationMethod = ClassificationMethod.DefinedInterval;
      defiendIntervalNodeRendererDef.IntervalSize = 4;
      defiendIntervalNodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
        if (tinLayer.CanCreateRenderer(defiendIntervalNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(defiendIntervalNodeRendererDef);
    Elevation Node Renderer - Standard Deviation
      var stdDevNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      stdDevNodeRendererDef.ClassificationMethod = ClassificationMethod.StandardDeviation;
      stdDevNodeRendererDef.DeviationInterval = StandardDeviationInterval.OneHalf;
      stdDevNodeRendererDef.ColorRamp = ColorFactory.Instance.GetColorRamp("Cyan to Purple");
        if (tinLayer.CanCreateRenderer(stdDevNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(stdDevNodeRendererDef);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMTinRenderer
             ArcGIS.Core.CIM.CIMTerrainAttributeRenderer
                ArcGIS.Core.CIM.CIMTinColorRampRenderer
                   ArcGIS.Core.CIM.CIMTinNodeElevationRenderer
    Requirements
