ArcGIS.Core.CIM Namespace / CIMTinRenderer Class
Members Example
    Represents a TIN renderer.
    Syntax
    Example
    Get Renderers
      await QueuedTask.Run(() =>
        // get the list of renderers
        IReadOnlyList<CIMTinRenderer> renderers = surfaceLayer.GetRenderers();
        // get the renderers as a dictionary
        Dictionary<SurfaceRendererTarget, CIMTinRenderer> dict = surfaceLayer.GetRenderersAsDictionary();
    Simple Node Renderer
      // applies to TIN layers only
      var nodeRendererDef = new TinNodeRendererDefinition();
      nodeRendererDef.Description = "Nodes";
      nodeRendererDef.Label = "Nodes";
      nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
        if (tinLayer.CanCreateRenderer(nodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Elevation Node Renderer - Equal Breaks
      var equalBreaksNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      equalBreaksNodeRendererDef.BreakCount = 7;
        if (tinLayer.CanCreateRenderer(equalBreaksNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(equalBreaksNodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Elevation Node Renderer - Defined Interval
      var defiendIntervalNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      defiendIntervalNodeRendererDef.ClassificationMethod = ClassificationMethod.DefinedInterval;
      defiendIntervalNodeRendererDef.IntervalSize = 4;
      defiendIntervalNodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
        if (tinLayer.CanCreateRenderer(defiendIntervalNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(defiendIntervalNodeRendererDef);
    Elevation Node Renderer - Standard Deviation
      var stdDevNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      stdDevNodeRendererDef.ClassificationMethod = ClassificationMethod.StandardDeviation;
      stdDevNodeRendererDef.DeviationInterval = StandardDeviationInterval.OneHalf;
      stdDevNodeRendererDef.ColorRamp = ColorFactory.Instance.GetColorRamp("Cyan to Purple");
        if (tinLayer.CanCreateRenderer(stdDevNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(stdDevNodeRendererDef);
    Simple Edge Renderer
      // applies to TIN or LAS dataset layers only
      var edgeRendererDef = new TinEdgeRendererDefintion();
      edgeRendererDef.Description = "Edges";
      edgeRendererDef.Label = "Edges";
      edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Edge Type Renderer
      var breaklineRendererDef = new TinBreaklineRendererDefinition();
      // use default symbol for regular edge but specific symbols for hard,soft,outside
      breaklineRendererDef.HardEdgeSymbol = hardEdgeSymbol.MakeSymbolReference();
      breaklineRendererDef.SoftEdgeSymbol = softEdgeSymbol.MakeSymbolReference();
      breaklineRendererDef.OutsideEdgeSymbol = outsideEdgeSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(breaklineRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(breaklineRendererDef);
    Contour Renderer
      var contourDef = new TinContourRendererDefinition();
      // now customize with a symbol
      contourDef.Label = "Contours";
      contourDef.SymbolTemplate = contourLineSymbol.MakeSymbolReference();
      contourDef.ContourInterval = 6;
      contourDef.IndexLabel = "Index Contours";
      contourDef.IndexSymbolTemplate = indexLineSymbol.MakeSymbolReference();
      contourDef.ContourFactor = 4;
      contourDef.ReferenceHeight = 7;
        if (surfaceLayer.CanCreateRenderer(contourDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(contourDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Contours))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Contours);
    Simple Face Renderer
      var simpleFaceRendererDef = new TinFaceRendererDefinition();
      simpleFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(simpleFaceRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(simpleFaceRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
    Aspect Face Renderer
      var aspectFaceRendererDef = new TinFaceClassBreaksAspectRendererDefinition();
      aspectFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
      // accept default color ramp
        if (surfaceLayer.CanCreateRenderer(aspectFaceRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(aspectFaceRendererDef);
    Slope Face Renderer - Equal Interval
      var slopeFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      // accept default breakCount, symbolTemplate, color ramp
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksEqual))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksEqual);
    Slope Face Renderer - Quantile
      var slopeFaceClassBreaksQuantile = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      slopeFaceClassBreaksQuantile.ClassificationMethod = ClassificationMethod.Quantile;
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksQuantile))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksQuantile);
    Elevation Face Renderer - Equal Interval
      var elevFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition();
        if (surfaceLayer.CanCreateRenderer(elevFaceClassBreaksEqual))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(elevFaceClassBreaksEqual);
    Dirty Area Renderer
      var dirtyAreaRendererDef = new TerrainDirtyAreaRendererDefinition();
      // accept default labels, symbolTemplate
      if (terrainLayer == null)
        return;
        if (terrainLayer.CanCreateRenderer(dirtyAreaRendererDef))
          CIMTinRenderer renderer = terrainLayer.CreateRenderer(dirtyAreaRendererDef);
          if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.DirtyArea))
            terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.DirtyArea);
    Terrain Point Class Breaks Renderer
      var terrainPointClassBreaks = new TerrainPointClassBreaksRendererDefinition();
      // accept defaults
        if (terrainLayer.CanCreateRenderer(terrainPointClassBreaks))
          CIMTinRenderer renderer = terrainLayer.CreateRenderer(terrainPointClassBreaks);
          if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Classification Unique Value Renderer
      var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
      // accept the defaults for color ramp, symbolTemplate, symbol scale factor
      if (lasDatasetLayer == null)
        return;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Returns Unique Value Renderer
      var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
      lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
      lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
    LAS Points Elevation Stretch Renderer
      var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      // accept the defaults for color ramp, etc
      if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
        CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
      // OR use a stretch renderer with stretchType standard Deviations
      var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
      elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
        if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
    LAS Points Classified Elevation Renderer
      var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
      lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
      // increase the symbol size by a factor
      lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
    Inheritance Hierarchy
    Requirements
