Public Class CIMMeshSymbol Inherits CIMMultiLayerSymbol Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMMeshSymbol : CIMMultiLayerSymbol, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
/// <summary> /// Create a mesh symbol that can be applied to a multi-patch feature layer. /// A mesh symbol is a CIMMeshSymbol object. Define an array of CIMSymbolLayers which contains a CIMMaterialSymbol layer with the specified properties such as Color, etc. /// Assign this array of CIMSymbolLayers to the CIMMeshSymbol. ///  /// </summary> { //Note: Run withing QueuedTask CIMSymbolLayer[] materialSymbolLayer = { new CIMMaterialSymbolLayer() { Color = ColorFactory.Instance.CreateRGBColor(230,152,0), MaterialMode = MaterialMode.Multiply } }; var meshMaterialFillSymbol = new CIMMeshSymbol() { SymbolLayers = materialSymbolLayer }; }
/// <summary> /// Creates Mesh procedural symbol with various textures. ///  /// Note: The rule package used in this method can be obtained from the Sample Data included in the arcgis-pro-sdk-community-samples repository. /// </summary> { //Note: Run withing QueuedTask string _rulePkgPath = @"C:\Data\RulePackages\MultipatchTextures.rpk"; CIMSymbolLayer[] proceduralSymbolLyr = { new CIMProceduralSymbolLayer() { PrimitiveName = "Textures", RulePackage = _rulePkgPath, RulePackageName = "Textures", } }; var meshProceduralTextureSymbol = new CIMMeshSymbol() { SymbolLayers = proceduralSymbolLyr }; }
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMSymbol
ArcGIS.Core.CIM.CIMMultiLayerSymbol
ArcGIS.Core.CIM.CIMMeshSymbol
