ArcGIS.Core.CIM Namespace / CIMChartGeneralProperties Class
Members Example
    Provides access to members that control general chart properties.
    Object Model
    CIMChartGeneralProperties ClassCIMChartFillSymbolProperties ClassCIMChartGeneralProperties ClassCIMChartTextProperties ClassCIMChartGeneralProperties ClassCIMChartLineSymbolProperties ClassCIMColorRamp ClassCIMChartTextProperties ClassCIMChartTextProperties ClassCIMChartLineSymbolProperties Class
    Syntax
    Example
    Create a simple scatter plot
      //Note: QueuedTask is required to access the feature layer
        // For more information on the chart CIM specification:
        // https://github.com/Esri/cim-spec/blob/main/docs/v3/CIMCharts.md
        var lyrDefScatter = featureLayer.GetDefinition();
        // Define scatter plot CIM properties
        var scatterPlot = new CIMChart
          Name = "scatterPlot",
          GeneralProperties = new CIMChartGeneralProperties
            Title = $"{xField} vs. {yField}",
            UseAutomaticTitle = false
          Series =
              new CIMChartScatterSeries {
                  UniqueName = "scatterPlotSeries",
                  // Specify the X and Y field names
                  Fields = new string[] { xField , yField },
                  // Turn on trend line
                  ShowTrendLine = true
        // Add new chart to layer's existing list of charts (if any exist)
        var newChartsScatter = new CIMChart[] { scatterPlot };
        var allChartsScatter = (lyrDefScatter == null) ? newChartsScatter : lyrDefScatter.Charts.Concat(newChartsScatter);
        // Add CIM chart to layer definition
        lyrDefScatter.Charts = allChartsScatter.ToArray();
        featureLayer.SetDefinition(lyrDefScatter);
    Create a line chart with custom time binning and style
      // Note: QueuedTask is required to access the feature layer
        var lyrDefLine = featureLayer.GetDefinition();
        // Define line chart CIM properties
        var lineChart = new CIMChart
          Name = "lineChart",
            Title = $"Line chart for {dateField} summarized by {numericField}",
          Series =
                new CIMChartLineSeries {
                  UniqueName = "lineChartSeries",
                  Name = $"Sum({numericField})",
                  // Specify date field and numeric field
                  Fields = new string[] { dateField, numericField },
                  // Specify aggregation type
                  FieldAggregation = new string[] { string.Empty, "SUM" },
                  // Specify custom time bin of 6 months
                  TimeAggregationType = ChartTimeAggregationType.EqualIntervalsFromStartTime,
                  TimeIntervalSize = 6.0,
                  TimeIntervalUnits = esriTimeUnits.esriTimeUnitsMonths,
                  // NOTE: When setting custom time binning, be sure to set CalculateAutomaticTimeInterval = false
                  CalculateAutomaticTimeInterval = false,
                  // Define custom line color
                  ColorType = ChartColorType.CustomColor,
                  LineSymbolProperties = new CIMChartLineSymbolProperties {
                      Style = ChartLineDashStyle.DashDot,
                      Color = new CIMRGBColor { R = 0, G = 150, B = 20 },
                  MarkerSymbolProperties = new CIMChartMarkerSymbolProperties
        var newChartsLine = new CIMChart[] { lineChart };
        var allChartsLine = (lyrDefLine == null) ? newChartsLine : lyrDefLine.Charts.Concat(newChartsLine);
        lyrDefLine.Charts = allChartsLine.ToArray();
        featureLayer.SetDefinition(lyrDefLine);
    Create a bar chart
        var layerDefinition = featureLayer.GetDefinition();
        string fieldXAxis = "textField";
        string fieldYAxis = "NumericField";
        var myBarChart = new CIMChart
          Name = "Bar chart",
            Title = $"{fieldXAxis} vs. {fieldYAxis}",
          Series =
              new CIMChartBarSeries
            Name = "Bar chart",
            UniqueName = "Bar chart",
            Fields = new string[] { fieldXAxis, fieldYAxis },
            //Create green fill symbols
            FillSymbolProperties = new CIMChartFillSymbolProperties
                Color = CIMColor.CreateRGBColor(38, 115, 0, 70)
        var newBarCharts = new CIMChart[] { myBarChart };
        var allChartsBar = (layerDefinition.Charts == null) ? newBarCharts : layerDefinition.Charts.Concat(newBarCharts);
        layerDefinition.Charts = allChartsBar.ToArray();
        featureLayer.SetDefinition(layerDefinition);
    Create a histogram for every field of type Double
      var lyrDefHistogram = featureLayer.GetDefinition();
      // Get list names for fields of type Double
      var doubleFields = featureLayer.GetFieldDescriptions().Where(f => f.Type == FieldType.Double).Select(f => f.Name);
      // Create list that will contain all histograms
      var histograms = new List<CIMChart>();
      // Create histogram for each Double field
      foreach (var field in doubleFields)
        // Define histogram CIM properties
        var histogram = new CIMChart
          Name = $"histogram_{field}",
            Title = $"Histogram for {field}",
          Series =
                  new CIMChartHistogramSeries {
                      UniqueName = "histogramSeries",
                      BinCount = 15,
                      // Specify the number field
                      Fields = new string[] { field },
        histograms.Add(histogram);
      var allChartsHistogram = (lyrDefHistogram == null) ? histograms : lyrDefHistogram.Charts.Concat(histograms);
      lyrDefHistogram.Charts = allChartsHistogram.ToArray();
      featureLayer.SetDefinition(lyrDefHistogram);
    Create a multiseries bar chart
      var lyrDefBar = featureLayer.GetDefinition();
      // Get unique values for `splitByField`
      var values = new List<string>();
      using (RowCursor cursor = featureLayer.Search())
        while (cursor.MoveNext())
          var value = Convert.ToString(cursor.Current[splitByField]);
          values.Add(value);
      var uniqueValues = values.Distinct().ToList();
      // Define bar chart CIM properties
      var barChart = new CIMChart
        Name = "barChart",
          Title = $"{categoryField} grouped by {splitByField}",
      // Create list to store the info for each chart series
      var allSeries = new List<CIMChartSeries>();
      // Create a series for each unique category
      foreach (var value in uniqueValues)
        var series = new CIMChartBarSeries
          UniqueName = value,
          Name = value,
          // Specify the category field
          Fields = new string[] { categoryField, string.Empty },
          // Specify the WhereClause to filter a series by unique value
          WhereClause = $"{splitByField} = '{value}'",
          GroupFields = new[] { categoryField },
          FieldAggregation = new string[] { string.Empty, "COUNT" }
        allSeries.Add(series);
      barChart.Series = allSeries.ToArray();
      var newChartsBar = new CIMChart[] { barChart };
      var allBarCharts = (lyrDefBar == null) ? newChartsBar : lyrDefBar.Charts.Concat(newChartsBar);
      lyrDefBar.Charts = allBarCharts.ToArray();
      featureLayer.SetDefinition(lyrDefBar);
    Create a pie chart with custom legend formatting
      var lyrDef = featureLayer.GetDefinition();
      // Define pie chart CIM properties
      var pieChart = new CIMChart
        Name = "pieChart",
          Title = "Pie chart with custom legend formatting",
          UseAutomaticTitle = true
        Legend = new CIMChartLegend
          LegendText = new CIMChartTextProperties
            FontFillColor = new CIMRGBColor { R = 0, G = 250, B = 20 }, // Specify new font color
            FontSize = 6.0, // Specify new font size
        Series = [
                new CIMChartPieSeries
                   UniqueName = "pieSeries",
                   Name = "pieSeries",
      var newCharts = new CIMChart[] { pieChart };
      var allCharts = (lyrDef?.Charts == null) ? newCharts : lyrDef.Charts.Concat(newCharts);
      lyrDef.Charts = allCharts.ToArray();
      featureLayer.SetDefinition(lyrDef);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMChartGeneralProperties
    Requirements
